Another MM EFI vs Carb thread
Old Mar 23, 2014 | 06:47 PM
  #111
Bumpandrun's Avatar
Bumpandrun
Getting further behind. Have new CV ultima 2000i is here Have to order pingel stuff now. Swing arm looked pretty straight forward what wheel and tire? Thanks for showing tank. Going to have to use the 98 tank this year. No time for paint
Old Mar 23, 2014 | 08:57 PM
  #112
HGM's Avatar
HGM
Work in progress, but its an '04 swingarm, '06 FLX wheel, '08 rotor and brembo caliper, '05 pulley and a 1-1/8 x 139 tooth belt from an '05 bagger..... Sounds like a Johnny Cash song huh?
Old Mar 24, 2014 | 05:34 AM
  #113
grbrown's Avatar
grbrown
Thumbs up
Hi Greg, I currently have an '07 swingarm and brake caliper from a trike conversion, plus '04 wheel in my '90 Glide, and have just scored a new unused Brembo from another trike conversion, courtesy Ebay USA. That is somewhere mid-Atlantic at present! I'm interested to see what you do to adapt it to fit, as I understand it won't just bolt in.
Old Mar 24, 2014 | 09:37 AM
  #114
HGM's Avatar
HGM
Hey Graham,
I've got the Brembo installed on the bike, though I'm waiting for the rotor and pulley to complete assembly. The bracket is 25mm and needs to be taken to 1". Thats really the biggest issue so far, but really not at all.. I simply used an old wheel cylinder hone and opened it up, took a bit, but worked just fine, its only .016".. Though it may not be ideal, I used the original master and blead the DOT4 out of the brembo, replacing it with DOT5. Stock brake line fits just fine.. So far so good.. The unexpected engine work has REALLY slowed my progress, so I've been hessitant to provide much update, knowing I cant road test it for a while.. I'll keep you guys posted and intend to do a build thread on each update.. This should be a completely different bike when I'm done..
Old Mar 25, 2014 | 12:39 PM
  #115
grbrown's Avatar
grbrown
Hi Greg, my swish 'new' rear Brembo turned up this afternoon and looks jolly good. I have other things to solve before installing it, so will put it to one side for now.
Old Mar 25, 2014 | 12:59 PM
  #116
HGM's Avatar
HGM
Should look something like this
Excuse the blue bolts, HD didnt have the correct ones in stock, so I used transmission bolts for mock up and bleading..
Old Mar 25, 2014 | 01:05 PM
  #117
grbrown's Avatar
grbrown
Thumbs up
Still very much in its box, but otherwise the same!
Asuperglide
EVO
15
Dec 14, 2016 07:45 PM
SuperG96
Jun 25, 2015 06:12 AM
Beemervet
EVO
41
Apr 20, 2015 12:53 PM
95 Ultra
EVO
Jan 6, 2010 03:01 PM
schoney
Exhaust System Topics
May 19, 2007 11:47 AM
