Another MM EFI vs Carb thread
Not to hijack, There is much food for thought here, both pros and cons of the swap. I have been riding the same 97 ultra with MM e.f.i. for the past 126,000 miles and have had absolutely NO issues with it, (well there was that ECM relay once) other than tuneability (or the lack thereof). Every time I made a change, i.e. pipes, a-c, cam, mild porting, etc. the bike almost seemed to learn itself in a short amount of time. does that sound right or is it just me? Yes, it was never exactly the same, but seemed to be closer the more I rode it. But I digress. I have recently made the decision to do a carb/ignition system swap. I found an S&S E complete kit for 200 bones, and a crane hi-4 dual, for the price of a pillow seat that I would never use again. After all the incident free miles I have put on the MM f.i., I am absolutely positive that I will have no regrets taking "Nadine" back to the stone age so I can reap ALL the benefits of the changes I have made to her, at a reasonable price. (the complete swap for the price of a map and tune on the dyno) Like I said, didn't want to hijack, just my 2 cents worth. Will let you know how it turns out. Will have a COMPLETE MM system from a 97 ultra available when this project is completed. Everything works fine, like I said, just swapping for tuneability.
1- What exactly do I need for ignition? I'm expecting a pick up, module and trigger wheel. Will one of the aftermarket type's make a simpler/cheaper option?? recommendations?
2- Anyone know what the internal diameter is of the tank fittings? I can figure it out as I go to take it apart, but I'm devising a plan to cut the inside tube, before I actually disable the bike.. Pictures in the tank would be awesome!
3- Will I be able to use my stock cables??
Thanks for any input! I plan to do a thread on the actual job, to make it a little easier to track this stuff down in the future..
ignition: nearly any aftermarket will do. i had excellent luck with my Dyna2000p (which is sitting in a drawer right now, new engine came with an IST ignition). trigger wheel is OEM (or aftermarket, doesn't really matter as its a rather simple piece of gear. OEM is $150+, aftermarket was $40...easy choice for me)
dont remember ID of tank fittings, but I used a dremel cutoff wheel, and cut from the outside of the tank (inside the threaded bits) inwards. it was nearly impossible to get the angle i needed from inside the tank.
I used my stock MM EFI cables on my Mikuni when I did my swap (using the stock bars at the time). they were adjusted out pretty far, but they did work
If you find yourself needing swap parts, shoot me a PM with what you need. I probably have it sitting in a box here
I put a magnet in the tank when drilling to try and catch as many shaving as possible. Make sure you clean the tank out well when you are done.
If I were to use the Dyna2000p, will I also need an ignition module, or is that the whole system?? I'm visualizing a stock set up with the pick up and module being separate..
So, my next question, do I need a coil as well??
Sorry for the ignorant questions, but I'm just not familliar with the aftermarke and the descriptions dont seem to spell it out for me.. I appreciate the help and patience..
