Your opinions appreciated.
The motor was Harley remand at 100k.
I have been thinking about having the heads ported and installing 9.5-1 pistons.
About the fastest I ride is 80 mph but I usually run about 70 mph.
My question is this---
Is it really worth the expense?
The reason I ask is that the motor is running good and I have a hard time tearing into a perfectly good motor.
I'd like the extra horse power but I just don't see me using it that much.
What do ya'll think?
So beware - this can become a bit of a drug - a little leads to a little more, etc. IMHO if you do any tuning, make it a significant improvement in performance, so it is worthwhile and effective. And it is torque you want, horse power is a by-product!
It's not really how fast you are going to run down the road, it's how fast you get there and how much you like passing other vehicles...
Im not a fan of pulling apart a good running motor for just performance enhancements especially if you are happy with it now. But there is a big difference after you do it and there will be a smile on your face when you get on it... My EVO is done, the twinkie is stock at only 6K miles and runs perfectly. I can't wait for it to get to 25 so I have an excuse to do cams and etc... The EVO smokes it badly right now...
Ds
Is this true?
I decided that it was likely that I would rebuild at some point, but given my age it seemed as though I could enjoy it longer if I just went ahead and did so sooner rather than later.
I went with the EV27 cam, a classic for bumped compression (Mine are 10:1 Wiseco), this cam is for us old guys with heavy bikes that don't live at extreme rpm's, better response all the way across the 1500-6000 rpm range. I had previously switched to a tweaked CV carb with semi-polished manifold (Cleaned up mold parting lines.), Free flow intake etc. Complete Valve re-work, and my indy is a fan of Port flow for EVO's which to him is a rounding of corners on the intakes and Exhaust, accompanied by a slightly rough polishing thoughout. By not having a mirror finish on head surfaces better atomization of the fuel is believed to be the end result.
Steel breather gear, cometics, upgraded ignition complete the package.
Probably going with a 2 into 1 exhaust as well. I'm guessing that I am at 75-80 H.P. already, and after an E-Mail exchange with Bruce Schultz at SuperTrapp I'm comfortable with the belief that I will top 80/80 once my pipe is switched.
Smoother, more oommph! Definitely glad that I did so. I use Hi-Test now, but I also get better mpg, but I have been more aware of wrist twist while breaking it in. We'll see if this lasts.
No obvious pinging to date with Hi-Test. Haven't run it in very hot weather though either (Hot is relative, I'm in N.Y.)
Pop over to the Tech Engine forum, where you will find a few HDF sponsors who are top engine tuners. They are the sort of chaps you can send your cylinders and heads to and get them back reworked with a package of all the new parts you need to rebuild - a one-stop-shop!
Here's one possibility, just to whet your appetite, 90/90.
