Front Wheel Bearings '96 RK
Old Mar 26, 2014 | 06:49 PM
  #71
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Damn good video..
Thanks.
Old Mar 27, 2014 | 07:50 AM
  #72
Jackie Paper's Avatar
Jackie Paper
Originally Posted by Hopper
I'm not sure why HD specifies the loose fit. Maybe because a little too much preload will cause premature wear much quicker than a little too loose.
Back in the 60's I went to a class, as an engineer on a design team that was engineering a gear box for a 7' deep penetration drilling application for pipe penetrations in a reactor on board of a submarine. It was brought out that it was normal to preload a tapered bearing in an oil bath application. However, in a greased application, the norm was not to preload and longer bearing life would come from as little as .0002 end play which would prevent the bearing going dry in a vibrating and non rolling application such as transportation applications. They had discovered this when GM started shipping their cars by railroad. In the field, .0002 would be a silly statement and I think Harley's upper loose tolerance is pretty extreme. I know if you preload the tapered fork bearings much over the fall off limit, it will cause them to clack on bumps which is opposite of what I would have thought would happen.
Old Mar 27, 2014 | 09:27 AM
  #73
talon0930's Avatar
talon0930
I agree Texashillcountry...I searched all over for detailed information like this, to explain in simple terms what end play is and how to adjust it....now I can add yet another task to my list of things NOT to go to the dealer for! I called around to 4 dealers in my area, got prices to just pull old and put new races in....range was 40 to 120 bucks.....one tried to tell me the dealer HAD to set end play and would be 1.5 hours labor......YIKES!
Old Apr 5, 2014 | 02:31 PM
  #74
talon0930's Avatar
talon0930
Well I bought a new dial indicator and magnetic base to set up my end play, took me a little bit of time to get my end play set within the 0.002-0.006" spec. I ended up at between 0.003-0.004" after putting everything together and taking back apart 5 times. I could have gotten it right at the 0.002" but the dealer did not have any 0.002" shims, so I only had a 0.004" to put in. I am extremely happy with the way it felt today when I finally got out for a good ride. All the other things I did to the front end really made a huge improvement. My old bearings were not horrible, but I did see some wear, and now I can feel the difference with all new in.....tracks much better.
Old Apr 10, 2014 | 08:35 PM
  #75
Maxdog2's Avatar
Maxdog2
Great video. I am replacing the tires and packing the wheel bearings. They look good, but I will check the end play. Thanks for sharing.
Old Apr 20, 2014 | 03:33 PM
  #76
Kozmo's Avatar
Kozmo
Update!
Back on the road. Front wheel bearings changed and all is good. Thanks to all for the help and comments.
Yall ride safe!
  #77
Kozmo's Avatar
Kozmo
Double post
Old Apr 20, 2014 | 04:38 PM
  #78
Spanners39's Avatar
Spanners39
Originally Posted by Kozmo
Update!
Yall ride safe!
It is not my favourite job on a Harley, I don't trust the "off the bike" method as it is possible to inadvertently get the axle torque and pre-load wrong....if you do it on the bike you can be 100% sure that the end play is the same as it will be under its working conditions.
1.5 hours is about right for setting end play, assuming that it doesn't go right first go.
Old Jun 30, 2014 | 11:26 AM
  #79
talon0930's Avatar
talon0930
When I did my front wheel end play, it was the first time I ever did it. I understand now why a dealer would quote 1.5 hours......it took me probably longer to get it just right. I am sure if I had to do it again, I could shave that time in half.
Was well worth the experience to do the job right and at home!
Old Jun 30, 2014 | 11:38 AM
  #80
grbrown's Avatar
grbrown
Thumbs up
Also helps to explain why the MoCo went to sealed ball races - to reduce assembly time in production!
