EV27 cam.....do I need to run adjustable pushrods?
Old Feb 1, 2014 | 09:01 AM
panz4ever's Avatar
panz4ever
I guess you can say HD has been running these since `52, as long as you ignore the fact that they stopped using them 30 years ago.
Nope, not ignoring that at all. Valid point. My bikes run the gamit from 26 to 65 years old. On the bikes with adjustable I haven't lost one yet. There could always will be a first time though..
Old Feb 1, 2014 | 02:17 PM
Spanners39's Avatar
Spanners39
The original question was "do I NEED adjustables with an EV27?"
The answer is no...
Old Feb 5, 2014 | 01:07 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
The answer is no...
When did staying on topic become important?
Old Feb 5, 2014 | 02:19 PM
Spanners39's Avatar
Spanners39
When I say it does....
Old Feb 5, 2014 | 02:46 PM
johnjzjz's Avatar
johnjzjz
The reason for the change is its cheaper to have non adjustable push rods
BUT always a BUT -- if your going to ASSUME that the 10 or 15 different cam shaft manufacturers are using the exact same numbers, for the base circle distance runout from center line -- and yes only a couple thousants or so is all we have ever found with the cams we checked - for stock or neer stock engines with small camshafts that do not change the dymanics of the engine too much Sure use them -- and an EV 27 is what most run thats fine -
Old Feb 5, 2014 | 07:11 PM
panz4ever's Avatar
panz4ever
Deleted
boygenius
EVO
18
Jul 28, 2014 09:24 AM
fastmofo01
EVO
19
May 27, 2014 07:46 AM
jackhis
Sep 28, 2010 04:27 PM
omgtkk
EVO
Aug 28, 2010 02:57 AM
HDRider2002
Feb 20, 2009 12:51 PM
