The old battery question
Old Feb 11, 2014 | 08:38 AM
JohnnyC's Avatar
JohnnyC
Odds are good it's loose connections at the battery, or where the main cables mount. It typically isn't corrosion that causes a full power outage, but it can be. So check the other ends of the main lines too.
Just looked up the lithium, it sells for almost $300.
My last HD OEM was $129 if I remember correctly. This will be it's 5th year if it makes it. 4 years are typical.
Trickle charge during the off season and in between rides seems to keep them in good running condition for a number of years.
Just curious, other than it being very light what makes Lithium worth twice the cost? All I saw was number of cells (16) and no other data. Perhaps they hold a higher cranking current?
Old Feb 11, 2014 | 11:15 AM
bluharley's Avatar
bluharley
It's not the battery. Time for a new thread!
Old Feb 12, 2014 | 08:54 AM
JohnnyC's Avatar
JohnnyC
SO have you traced down the power relay?
Total power loss starts at the battery connections and goes a long ways to power lights and ignition. A few miles of wires and connectors in-between.
Not understanding why you want to start over??
Old Feb 12, 2014 | 09:19 AM
bluharley's Avatar
bluharley
The battery tested good. Turned out to be the terminal on the starter.
Old Feb 12, 2014 | 10:34 AM
tmanbuckhunter's Avatar
tmanbuckhunter
Lithium lasts longer, and is stronger.
Old Feb 12, 2014 | 10:35 AM
JohnnyC's Avatar
JohnnyC
Good to know what the outcome was. Glad you traced it down. Guess that finishes this issue.
Old Feb 12, 2014 | 11:16 AM
miacycles's Avatar
miacycles
Yes lithium will crank our big bagger over faster than an '80" engine even if we don't use the compression releases!! It has a lot more CCA's.
John!!!!
Old Mar 20, 2014 | 10:45 PM
turnerbend's Avatar
turnerbend
Mine had a Walmart battery in it when I got it. It was too small, and it lasted about 4-5 months I think. This will be my 3rd Deca in 7 years, not too bad considering the summers here. "They" say, 2 years is average for a battery in this environment. And this one isn't dead yet, but I have to hit the button twice to get it turned over, and when it was cold the other day it took 4 or 5 to get it to turn over. I'm not waiting 'til I get stranded.
3 batteries in 7 years???? That's a lot of batteries......I get 5 to 11 years on batteries in my cycles, cars and trucks. You may want to consider buying a different type battery or checking your charging system...
Old Mar 20, 2014 | 11:47 PM
cowboy 51's Avatar
cowboy 51
well Harley does' not make there own battery's , can't think off hand now who make them for HD ,deca I think
Old Mar 21, 2014 | 02:22 AM
Ken Oaff's Avatar
Ken Oaff
had that grief with acid batteries except they lasted about 12 months each
switched to hd gel battery and it lasted 9 years
