Fuel valve
Old Feb 24, 2014 | 12:15 PM
Springer Boy's Avatar
Springer Boy
Default Fuel valve
Hi all
I need some help please. I am doing some routine maintenance, which includes cleaning the little filter in the fuel tap on my carbureted Evo Softail Springer.
Now, the Clymer manual, as well as the Owners Manual both give the same basic instructions, drain the fuel by opening the fuel tap to Reserve.
However, the fuel tap is vacuum activated so it only works when the engine is running. So how on earth do you drain the tank before removing the fuel tap?
I suppose I can drain it from the cross-over? What would be the correct procedure?
Cheers
KC
Old Feb 24, 2014 | 12:34 PM
HGM's Avatar
HGM
Originally Posted by Springer Boy
Hi all
Cheers
KC
I have drained it by the crossover, just be ready for a mess.. I'm guessing there would be a vac port on the valve though, so you could just use a vacuum pump to pull a vac on it to allow it to drain.. Never done one of those, myself, but thats the first thing to come to mind..
Old Feb 24, 2014 | 01:29 PM
shadowchrome's Avatar
shadowchrome
The vacuum pump should do it, that's what I tried to use on mine. Unfortunately my petcock had a pinhole and wouldn't hold a vacuum so I had to use the cross over. I pumped that thing up and it kept bleeding down on me. When I got it drained I replaced it with a normal one!
Old Feb 24, 2014 | 02:09 PM
tomfiii's Avatar
tomfiii
If you have gas with alcohol blend in your area and fuel lines are several years old ,replace them now! As they deteriorate on inside.
Old Feb 24, 2014 | 03:00 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Hi all
Cheers
KC
When mine still had the vacuum petcock I just got a 4' long piece of 1/4" fuel line and siphoned it out of the gas tanks into a gas can.
Toss that stock petcock and get a non-vacuum Pingle.
Old Feb 24, 2014 | 03:27 PM
Dr.Hess's Avatar
Dr.Hess
Yeah, after you clean this mess up, get the Pingle. And I would have tried the vacuum pump too.
Old Feb 24, 2014 | 03:39 PM
tmanbuckhunter's Avatar
tmanbuckhunter
I just yank the crossover line, and pull the tank off real fast and then hook it back up and clean up my mess... if I want to drain it I hook a hose up to the other spout for the cross over and slide them into a gas can.
I need to replace that damn vaccum operated junk badly...
Old Feb 24, 2014 | 03:41 PM
Beemervet's Avatar
Beemervet
In anticipation of future work I bought a quick release coupler for the crossover line. It has saved me a lot of gas fumes.............
Old Feb 24, 2014 | 04:33 PM
HarDlife's Avatar
HarDlife
Just use a large funnel with a hose and break the nut loose on the tank. Your taking the petcock out anyway, right? And like others have said, toss that vacuum crap and get a regular petcock. I got a oe type non-vacuum j&p petcock for 20 bucks, works like a champ.
Old Feb 24, 2014 | 04:48 PM
texashillcountry
Dirt don't hurt
It also saves that last little bit of gas that is in the tanks when you drain them.
One of the bests mods I've done.
