Here we go ! Another rebuild thread
Old Mar 9, 2014 | 08:43 PM
  #31
highbarst's Avatar
highbarst
Fixed one of my problems to every time i wanted to put my sissy bar I would have to hold a wrench just rite between the tire and fender to get the nuts loose . I bolted up the rear fender with the bag brackets and tightened everything down then welded a piece of 3/16 rod across all 3 bolts . Now no more wrench is needed on the inside .
[IMG][/IMG]
[IMG][/IMG]
Made a nice extension for my oil gauge with a nice chrome bracket then found it was rite below my exh. Back to drawing board ended up cuting the 4" piece of pipe down to 1 1/2" and rethreading the end ' it now sits inside the exh.
[IMG][/IMG]
Here's the final setup no pic with exh on .
[IMG][/IMG]
[IMG][/IMG]
Got the exh. all set up just had to grind a little off the tie plate for 1 tranny bolt to clear.
[IMG][/IMG]
[IMG][/IMG]
Wired in a new tail light and installed the rear fender and wheel just need to pick up some new acorn nuts for the fender this week .
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Mar 28, 2014 | 08:06 PM
  #32
highbarst's Avatar
highbarst
figured I would just post a bunch when i got done with it , well almost done . This pig is getting loaded into the trailer tomorrow night and off to Vics to get started on the dyno Sun. morning a few heat cycles then tune and adj. carb .
[IMG][/IMG]
Wiring up the bars a few week ago .
[IMG][/IMG]
[IMG][/IMG]
Setting up the dash after putting the diamond plate on I had to readjust everything .
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Went to bleed my rear brake last weekend and ended up snapping the bleeder off spent $8 on a bleeder repair kit . exh. wrapped and now it's all buttoned up.
[IMG][/IMG]
[IMG][/IMG]
Old Mar 28, 2014 | 08:20 PM
  #33
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Looks damn good!!!!!!!!!!!!!!!
Old Mar 30, 2014 | 05:19 PM
  #34
highbarst's Avatar
highbarst
Made it to the builders today and got it fired up did 3 heat cycles and then checked the fuel mixture for a 500 mi. break in . Just pulling the bike back in the trailer and back into my garage I can definitely feel the difference already idle is almost as smooth as a twinkie .
[IMG][/IMG]
[IMG][/IMG]
Old Mar 30, 2014 | 05:23 PM
  #35
highbarst's Avatar
highbarst
Default It's alive !
This was the initial start up sorry for the noise he uses a vacuum to pull exhaust through a wide band air/fuel sensor .
Old Mar 30, 2014 | 05:42 PM
  #36
highbarst's Avatar
highbarst
The first run through the new 6 spd. again sorry for the sound will do a few more heat cycles this week at home and will try to get a video .
Old Mar 30, 2014 | 05:48 PM
  #37
TheBanditColorado's Avatar
TheBanditColorado
Looks and sounds awesome. Hell of a build!!!
Old Mar 30, 2014 | 05:51 PM
  #38
HarDlife's Avatar
HarDlife
Congrats HB! That TH sounds sweet on there, good job man!
Old Mar 30, 2014 | 05:59 PM
  #39
Rabbito's Avatar
Rabbito
I love the look of those bars with the front end looks sick bro
Old Mar 30, 2014 | 07:09 PM
  #40
wild_one's Avatar
wild_one
HB that's a hell of a build you've got going there. And to think this all started from oil consumption. Motor sounds really good.
