New issue. Never ends...
Old May 25, 2014 | 11:31 PM
1skrewsloose's Avatar
1skrewsloose
Originally Posted by Maxdog2
Mine had a noise/rattle at idle. It was on of the clips broken on the front brake pads. Chased the noise for ever.
Same with mine, took a while to realize the noise quit when I touched the front brake. Annoying little sob's.
Old May 26, 2014 | 05:51 AM
Doug S's Avatar
Doug S
Same....LOL
Get a good set of ear plugs and enjoy your ride....
Ds
Old May 26, 2014 | 06:08 AM
br549A1's Avatar
br549A1
If that's all it is great but it doesn't do it cold and when I hear odd noises I like to know it's nothing important before I ignore it. I will definitely check those when it jingles next
Old May 26, 2014 | 09:58 AM
Son of PMS's Avatar
Son of PMS
When mine makes that sound it's the exhaust heat shield. It doesn't always do it, seems to need to be just the right conditions and it will rattle.
The weld for the heat shield clamp on the front pipe had broken on mine. I patched it with some hi temp the epoxy, JB Weld or something.
Old May 26, 2014 | 12:28 PM
br549A1's Avatar
br549A1
Here's a video. Easier to hear in person. It's not the exhaust shields or brakes. I touched everything nothing stops it checked the battery box too
Old May 26, 2014 | 01:44 PM
tmanbuckhunter's Avatar
tmanbuckhunter
Definitely something loose... Check to see if you have an exhaust heat shield hose clamp break. I had one break and it sounded JUST like that.
Old May 26, 2014 | 03:16 PM
br549A1's Avatar
br549A1
. Checked all exhaust parts and clamps. I actually replaced those recently. Had a busted one before
Old May 26, 2014 | 04:01 PM
tmanbuckhunter
You said it goes away once its warm?
Old May 26, 2014 | 04:06 PM
br549A1's Avatar
br549A1
. Nope. Starts when it's warm normally but today I heard it cold. Went for a ride and did the video when I got home. I just rechecked all exhaust bolts and heat shield clamps too
Old May 26, 2014 | 05:28 PM
Kabear's Avatar
Kabear
It is the gasket in the cross-over pipe. The asbestos is all burnt out and only the metal ring remains. What you are hearing is the metal ring(looks like a copper washer) vibrating in the pipe.
Heat causes the pipes to expand when hot and it gets loose.
