Down shift squeal?
Old Jul 13, 2014 | 08:11 PM
factorybuilt's Avatar
factorybuilt
Default Down shift squeal?
I was reading the "Evo Shake" thread and I read this post from Throttle Jockey....
"In the video it looks like the outer race of the bearing is loose in the hub. Have you ever noticed a "squealing " noise if you come off the clutch hard? If it has in fact spun , I have used a center punch and peened the hub to tighten the bearing. Of course this is not a permenant fix , but it will get you by until your winter hits. "
Today, I heard that squeal when I came off the clutch hard while down shifting.
51,500 miles on my Ultra Classic. Is that what I am looking at?
Thanks
Old Jul 13, 2014 | 09:46 PM
Throttle_Jockey's Avatar
Throttle_Jockey
You say you down shifted hard. Are you sure you didn't just "chirp" the rear tire?
Old Jul 14, 2014 | 12:28 AM
D_gyver's Avatar
D_gyver
that bearing only spins when you pull in the clutch. get the bike up to 60mph in 5 gear pull in the clutch and let the motor idle or hit the kill switch and coast down to 20mph with it in gear and clutch pulled and listen for the squeal and also if its real bad feel for a vibration
Old Jul 14, 2014 | 05:07 PM
1997bagger's Avatar
1997bagger
Drive belt will bark if it slips across the trans pulley. They run on the outer part of the pulley when going forward, I know the belt moves and it should walk inward on de-accell. Mine will sometimes bark when I take off after useing gearing to slow down to a stop sign. Clutch can do this but staying with the belt chirp, bark, squeal sound or what ever you want to call it, just a theory.
Old Jul 14, 2014 | 08:40 PM
factorybuilt
Thanks for the info. As soon as the polar air invasion leaves and the sun decides to shine again, I will check those items out. It was 55 today rain and wind. Man, it is the middle of July for Pete's sake.
graultytc88
Aug 6, 2016 08:51 AM
xbonz
Jan 15, 2015 07:12 PM
drm1978
EVO
Oct 11, 2014 04:25 PM
mxtrainer
Sep 3, 2012 06:37 PM
fixxr
Aug 28, 2010 07:58 PM
