I seem to have an inconsistent spark in the front cylinder.
I checked timing the other night and it was sparking and making the light work fine.
Tonight, it's making the timing light flash intermittently, and the miss I've been fighting goes along with the flash.
I have a new coil, wires, plugs, ignition. What else could it be?
just cause parts are new don't make them good , double check all the plugs or hook up , just might be a loose wire , if timing was out it would miss all the time
Swap the plug wires and see if it moves. New plugs? Swap the plugs. When the motor is running, grab the front plug wire with your bare hand. Does it throw you across the garage? Same test but with the coil?
