What would cause inconsistent spark?
Old Aug 1, 2014 | 08:47 AM
traildog's Avatar
traildog
Originally Posted by texashillcountry
I've said it before and I'll say it again.
Put a tach on that thing so you know exactly what is happening at what rpm.
I have no idea why Harley didn't put a tach one it from the factory.
It is something that should always be on a bike IMO.
Tach is on order.
Originally Posted by Dr.Hess
Dirty ignition switch or other dirty electrical connector shouldn't make only the front plug miss. You should be able to touch both plug wires without any shock. I usually use a grounded screwdriver, holding it by the plastic handle and running the metal over the plug wires. If you see/hear any spark, the wire is bad, or MAYBE the plug or wire to plug connector, but usually the wire. I find the grounded screwdriver to be less painful than the bare hand, but that's also a valid test.
You did swap the wires at the coil, right? Just the coil plugs. If it moves to the back jug, bad coil.
I'll do the swap tonight. I'm also picking up a spark tester.
Old Aug 1, 2014 | 02:35 PM
traildog's Avatar
traildog
Well. I don't think it's a spark problem now. The tester I bought (and maybe it's not a good way to test) lit up just like it was supposed to. Both cylinders the same.
I'm going to look at the jetting again.
Old Aug 1, 2014 | 02:52 PM
br549A1's Avatar
br549A1
Originally Posted by traildog
Well. I don't think it's a spark problem now. The tester I bought (and maybe it's not a good way to test) lit up just like it was supposed to. Both cylinders the same. I'm going to look at the jetting again.
iPhone? Youtube? Fixed in minutes. These guys will know once they see it live
Old Aug 1, 2014 | 03:36 PM
Dr.Hess's Avatar
Dr.Hess
You didn't ask how to fix a jetting problem or a carb problem. You asked what would cause inconsistent spark. I think we answered that one. Now, for your problem, have you tried Sea Foam? I hear it works well for things like that.
Old Aug 1, 2014 | 03:46 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Originally Posted by cowboy 51
if timing was out it would miss all the time
It might ping, it might kick back on start up, it might run weak.
But I would not call a misfire a symptom of incorrect timing.
Old Aug 1, 2014 | 03:56 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Having pondered on TD problem for what seems like ages (at least 2 minutes) I have come to believe his bike is drunk on too much seafoam!!!
Perhaps if he quit pouring that stuff in his bike all the time it would sober up and ride right????
Old Aug 1, 2014 | 04:08 PM
br549A1's Avatar
br549A1
I know what it is man. You don't have one of these. I have no miss, just a shake. I'll sell this to you if you want it will solve the miss and create a shake.
Attached Thumbnails What would cause inconsistent spark?-image-441126724.jpg
Old Aug 1, 2014 | 09:36 PM
traildog's Avatar
traildog
You bunch losers. Bwaaaaaaaaaaaa.... When I have a moment, I'll tell you what I did that seems to have helped immensely.......... Right after I get the breather bolt I snapped off out of the hole.........
The tech support at S&S a clue..............
Old Aug 1, 2014 | 10:07 PM
traildog's Avatar
traildog
So, the helpful gent at S&S told me that a pipe switch can do all kinds of weird stuff and suggested 2 things.
1. Change the intermediate jet to .028.
2. Remove the set screw ......................
Anyone know where the set screw I'm referring to is located?
The gent told me, if he was still wrenching, he'd have a drawer full of them.........
Can't wait to take a ride. I can tell you I was putting through the neighborhood at 15 mph, and I'm thinking the problem is gone.............
Old Aug 1, 2014 | 10:50 PM
92Fatty's Avatar
92Fatty
Great news. Lean misfire??????
