Swap the plug wires and see if it moves. New plugs? Swap the plugs. When the motor is running, grab the front plug wire with your bare hand. Does it throw you across the garage? Same test but with the coil?
Already made accidental contact with a plug wire when it was running and no, it didn't even come close to throwing me across the garage.
Should the shock really be that strong?
Is it during low rpms you're getting that. When I was doing my timing it would do that at 1000 rpms or right around idle. There's a few tests you can do on the ignition module and coils but I don't know if they work for aftermarket ignitions. If it was jetting shouldn't you be able to get it to where it's missing then slightly pull the enricher **** to change the mix and see if it cleans up?
I did try the enrichener trick. It killed the bike, no matter how little I pulled it.
When I turn off the accelerator pump, the problem almost disappears.
THC suggested a carb re-build. I'm leaning that way, but, I'm going to do some more testing first.
And, it is at low speed/rpms I'm getting the miss. I can ride anywhere the way it is, but, just as I like to keep her CLEAN, I like to think she's running PERFECTLY as well.......
Plus, it's kind of embarrassing to pull into the hood with the motor cutting out. I try to keep the RPM's up.
Dirty ignition switch or other dirty electrical connector shouldn't make only the front plug miss. You should be able to touch both plug wires without any shock. I usually use a grounded screwdriver, holding it by the plastic handle and running the metal over the plug wires. If you see/hear any spark, the wire is bad, or MAYBE the plug or wire to plug connector, but usually the wire. I find the grounded screwdriver to be less painful than the bare hand, but that's also a valid test.
You did swap the wires at the coil, right? Just the coil plugs. If it moves to the back jug, bad coil.
