difference between early and late top end gasket sets
Old Aug 27, 2014 | 04:52 PM
bigpup's Avatar
bigpup
Default difference between early and late top end gasket sets
Hey fellas,
going to eventually rebuild my evo, I have it all tore down but was curious what gasket set to order, 92 and earlier or 92 and later. I have a 89 bottom breather lower end and have screamin eagle top breather heads. Anyone know the difference with the earlier and later sets? Thanks
Old Aug 27, 2014 | 05:28 PM
FFF88's Avatar
FFF88
Originally Posted by bigpup
Hey fellas,
The later. Although ive used both. With top breather rocker boxes you should use the top breather rubber gaskets. Although i too have a bottom breather lower and top breather rocker boxes 93 and up. And i use cork gaskets. Could never get the rubbers to seal as well. I have even managed to get some cork top breather gaskets. Though they are far and few between and ive used pre 93 gaskets on breathers(not recommended). Most folks are fine with the top breather rubbers. The outside shape of the gaskets are the same pre 92 and 93 up but the top breathers have some additional material shaped to seal around the return passages and the umbrella valves. And most folks use steel for the lowest of the top end gaskets, Head to cylinder. Somebody feel free to correct any misinformation i may have given.
Old Aug 27, 2014 | 06:22 PM
johnjzjz's Avatar
johnjzjz
we use a blend in my shop - the newest rubber gaskets from Harley are very good and almost never leak - than we use the cometic tin for the base the head and the lower rocker box - that is what i use in my shop it makes no sense for us to do the job over for free for the few bucks different it costs to buy the right stuff ONCE
Old Aug 27, 2014 | 07:33 PM
bigpup's Avatar
bigpup
Thanks guys
rsking45
Engine Mechanical Topics
Mar 6, 2017 11:35 AM
12hdrk
Dec 7, 2013 10:06 AM
12hdrk
Nov 24, 2013 02:51 PM
AllenW
Exhaust System Topics
Apr 17, 2013 10:09 AM
hcruz
Oct 23, 2007 05:17 PM
