Screamin' Eagle Clutch
Old Sep 8, 2014 | 07:26 PM
flhchaz's Avatar
flhchaz
Default Screamin' Eagle Clutch
Anyone have any experience with a Screamin' Eagle clutch? I'm thinking about putting one in my '97 electra glide. The stock clutch has finally died.
Old Sep 9, 2014 | 02:57 AM
grbrown's Avatar
grbrown
Do you mean the entire clutch, or just the plates? Barnett do fine plate kits as well as clutches, as an alternative to consider.
Old Sep 9, 2014 | 05:58 AM
flhchaz's Avatar
flhchaz
Thank you sir! I am also the proud owner of an electra glide in blue.
I am just looking to replace the discs and spring plate. My local HD healer has a "kit" with an extra disc and heavy duty spring plate for $210.00. I have checked out the Barnett stuff on the usual retail sites and Barnett site itself, but I don't see that they offer a spring plate with out buying one of their Scorpion clutches. Maybe i'll call them and see what they say.
Old Sep 9, 2014 | 07:55 AM
grbrown's Avatar
grbrown
If your bike is close to stock you don't need a heavy duty spring. I have an S&S 107" in mine, with a Barnett HD spring. If they are still available you only need a stock spring, which will go well with a set of Barnett plates (which I also have!).
Old Sep 9, 2014 | 08:04 AM
flhchaz's Avatar
flhchaz
Thanks for the info! I emailed Barnett to see if they have any spring plates and am waiting on the reply.
Old Sep 9, 2014 | 08:34 AM
Throttle_Jockey's Avatar
Throttle_Jockey
No experience with the SE clutch. I run Barnett plates and Rivera gold spring. Like GR said with the stock/mild 80" Barnett plates and a new OE spring will be enough to last a lot of miles.
Old Sep 9, 2014 | 03:39 PM
Spanners39's Avatar
Spanners39
I have used the SE components and had no issues with them.
Old Sep 9, 2014 | 05:32 PM
0734's Avatar
0734
Not even mentioned, but you never know what we might be thinking about "down the road". Of course, the pull will be heavier, but that may not be an issue. What I can tell you is that the stock HD hydraulic clutch will not lift an SE clutch. It will half-*** lift it and they may be making stronger units. I have not checked on them or considered one in years. Jokers and some other names make good hydraulic clutch systems, but the MOCO units I've had experience with....just won't properly lift the stronger clutches.
Old Sep 9, 2014 | 11:37 PM
Owtlaw's Avatar
Owtlaw
Pretty sure the OP's 97 Glide doesn't have a hydraulic clutch.
Old Sep 10, 2014 | 03:36 AM
0734's Avatar
0734
Probably not, but I've installed a few for people that had weak hand issues and they work fine on a stock clutch, but are problematic on a stronger clutch set-up. I have a friend that has a 97 bagger and he does have a hydraulic clutch, because I installed it.
