engine noise
Old May 25, 2007 | 05:55 PM
roadking2005's Avatar
roadking2005
Stage II
Default engine noise
help,i just bought a 2005 roadking police fuelie,it has stock exhaust on it what my problem is it has the twin cam motor,im a first time harley rider use to ride vulcan classic anyways this bike makes a real loud sounding like a lifter going bad in a small block chevy,at andidile it doesnt make the noise but when you get into it with any kinda load its there ive taken to local harley shop and had mech look at it he said itsnormal,does anyone have this same problem and is going to strand me.and if i keep riding it what will happen i havent changed oil yet the bike was bought with only 2600 miles it now has 3300 miles the noise hasnt got any worse.
Old May 25, 2007 | 06:49 PM
Kingofcubes's Avatar
Kingofcubes
Default RE: engine noise
The issue is usually airated oil due to excessive engine temperature coupled with pinion shaft whip in the stock cam support plate. The bandaid fix is the heavier spring to up the oil pressure and straight weight oil. The real fix is one of our R&R cam plate/ cam covers which solve a whole liteny of problems.
Old May 25, 2007 | 06:58 PM
Hammer02's Avatar
Hammer02
I had similar issues last week in Myrtle Beach. It turns out one of my adjustable pushrods had not been properly tightened and had worked loose. Little to no noise at idle....tap tap tap under load. Worse when hot.
14SGS
Milwaukee Eight (M8)
14
Jun 13, 2017 04:49 PM
softail3333
Oct 18, 2012 09:04 PM
Schroeder1959
Apr 4, 2011 01:57 PM
1peter
May 29, 2009 10:51 PM
fxr85
May 25, 2007 10:55 AM
