SE Adjustable Push Rods
Old Jun 20, 2007 | 07:52 PM
2005UltraNC's Avatar
2005UltraNC
Default SE Adjustable Push Rods
Anyone compare the SE adjustable push rods against the stock push rods. Even though the stock rods are not adjustable, the ends appear much better than the SE's. In fact, the lower end is much smaller in diameter. I put the SE's on my new build and suspect a top end not getting enough oil - may be these SE push rods?
Anyone notice what I'm talking about?
Old Jun 20, 2007 | 08:00 PM
Doc 1's Avatar
Doc 1
Default RE: SE Adjustable Push Rods
Is here a reason you would think your not getting enough oil to the top end? Are you experiencing a noise up there? What did you have done to yourbike to have the push rods installed?
Old Jun 20, 2007 | 09:48 PM
2005UltraNC
I put in TW-26G cams, Big Bore 95", Flat Top Pistons, and the adjustable rods. Noticed that the lower round end on the SE's is quite a bit smaller in diameter than the stock rods.
As well, took out the SE's after I went through the 2.5 turns - installation instructions. The SE's were not near the same length as the stock rods.Does the 2.5 turns seem to work for everyone else?
Old Jun 20, 2007 | 09:58 PM
Doc 1's Avatar
Doc 1
2.5 to 3.0 turns will work fine but my question is why use the adjustable push rods when you don't need them. The S/E rods are .100 larger in diameter than any other push rod on the market which allows it to rub on the push rod tubes making a noise you don't need. There will be evidence of this by a wear ring that will appearat the top section ofthe rod itself.
If it where me I'd put the stock rods back in and be done with it. Mechanics don't want to take off the rockers to install the camsso they sell this step to the customer saying it will save them money.....but you just spent $150.00 for the rods, don't make since does it.
Old Jun 23, 2007 | 11:00 AM
kiwidave2's Avatar
kiwidave2
one thing that gets me is that some of these 'adjustable' pushrods do **NOT** permit removal without top-end disassembly.
Buyer beware.
(Crane Timesavers do just what it says on the tin, BTW...)
Old Jun 23, 2007 | 11:13 AM
Doc 1's Avatar
Doc 1
The longer the adjuster the weaker the push rod.....so the ones your complaining about are used when the base circle of the cam is different than stock but the builder still needs the integrity and stiffness of a good push rod. There are reasons for just about everything not just ease of installing.
Old Jun 23, 2007 | 07:48 PM
Freedom's Avatar
Freedom
2.5 ? 3 turns?
Ooops my notes said 4 turns.
Put them in yesterday, tear 'em out tonight [:@]
Old Jun 23, 2007 | 08:03 PM
Doc 1's Avatar
Doc 1
This setting is for SE push rods....not Andrews!!!
Old Jun 24, 2007 | 02:21 PM
Freedom's Avatar
Freedom
Thanx, Doc
Got a set of each, installed the screaming eagles at 4 turns. Hope I haven't bent another valve and rod. [:@]
Old Jun 24, 2007 | 10:00 PM
jmetro's Avatar
jmetro
the pushrods are shorter after the adjustment because the cam is bigger. if you put the stock pushrods back in, make sure the lifters are not bottomed out, or your world will suck when you fire it up.
