blow by question
Old Jun 23, 2007 | 09:28 PM
geezergliderider's Avatar
geezergliderider
Stage II
Default blow by question
hi all, I'm new to this site and have a couple questions. I'll search the forums for my answers but i thought maybe someone might have a quick answer for me on 1,..... How do i ensure that i have adequate crankcase ventilation? my '98 with 34,000 on it seems to be springing some leaks around the rocker boxes ( one is actually puffing a little pressure out of the bad spot in the gasket) and my know it all son thinks it might be a blow by issue... any help appreciated....ED
Old Jun 24, 2007 | 01:07 PM
jmetro's Avatar
jmetro
Default RE: blow by question
this is not blow by. the case breathes through the heads, usually into the air cleaner. sounds like you just have a leaky gasket. you have to change it anyway, so you can check the umbrella valves and head passages when you change the gasket. i always change both cyls gaskets, since every time you only do one, the other is sure to start leaking once you get it back together. (murphy's law)
P.S. tell your son that blow by is the combustion gasses leaking past the rings, and has nothing to do with the breathing system, esp since on a harley evo, there is a breather valve that times when the engine is allowed to breathe.
Old Jun 26, 2007 | 12:59 PM
ReeseSS's Avatar
ReeseSS
The S&S breather gear for your EVO will improve the crank case breathing, and their breather valve will take care of any blowby.
bigpup
EVO
Aug 27, 2014 07:33 PM
KYFATBOB
Feb 11, 2011 05:27 AM
jdbluedevils39
Dec 17, 2009 05:34 PM
jurob
EVO
Sep 21, 2009 08:24 AM
hcruz
Oct 23, 2007 05:17 PM
