Engine temp
Old Jul 10, 2007 | 10:39 PM
1320nut's Avatar
1320nut
Default Engine temp
95 Degree day, cruising around 70 to 75 MPH, 3000 RPMs. Temp was at 239 Dyna Superglide Custom, has factory oil cooler. Is this about right for engine temp?????
Old Jul 11, 2007 | 06:46 AM
Doc 1's Avatar
Doc 1
Default RE: Engine temp
Perfect.....
Old Jul 11, 2007 | 11:13 AM
HDWRENCH's Avatar
HDWRENCH
Nothing wrong with that.
Old Jul 12, 2007 | 05:22 AM
UltraDuke's Avatar
UltraDuke
my temp is up there, i am still under 500 on my new scoot, should cool down after break in, new pipes, intake, pcIII.
Old Jul 14, 2007 | 11:00 PM
tomtuna1978's Avatar
tomtuna1978
on a 110 day mine rins at 205 in traffic without anny oil cooler(stock bike,save for the v@h long shots and a k/n air filter) its a 99 nightrain!!
Old Jul 15, 2007 | 04:55 PM
iclick's Avatar
iclick
ORIGINAL: 1320nut
If it's a stone-stock '06 or '07 with O2 sensors that might be normal, but I wouldn't be happy with that temp and would consider it too high. My '07 SG (PCIII with O2-sensor eliminators) runs about 205° in those conditions and I also have an oil cooler. If you're still running the O2 sensors, you might consider some means of controlling the A/F, like a PCiII, SERT, or T'Max. You could also install another oil cooler in series with your HD cooler, like a Jagg mounted on the left downtube, for added cooling.
Old Jul 15, 2007 | 04:59 PM
iclick's Avatar
iclick
ORIGINAL: tomtuna1978
A '99 Night Train is an Evo, and you can't compare Evo oil temps with TC's, as TC's run much higher. My Evo RK rarely ran >180°, maxing out at 200° once or twice in the nine years I rode it. Part of the reason TC's run higher oil temps is the piston spray function that cools the engine more effectively. It makes the oil hotter but the engine runs cooler because the oil is absorbing the heat.
Old Jul 16, 2007 | 07:50 AM
Kingofcubes's Avatar
Kingofcubes
ORIGINAL: 1320nut
[/align][/align]Although this is about normal we run 20-30 degrees cooler with our R&R stage kits.[/align]
1sweetglide08
Dec 19, 2012 04:41 PM
Nwminnesota
30
Jun 28, 2012 10:37 AM
smadge
Mar 30, 2009 02:52 PM
roadking1893
Mar 9, 2009 10:51 AM
1320nut
Jul 9, 2007 12:51 PM
