compression ratio??
Old Sep 19, 2007 | 07:31 PM
draycer's Avatar
draycer
Default compression ratio??
If I use SE high comp cast piston set 10.25:1 will I actually get 10:25:1? I'm trying to be at 9.8:1 and hear I probably can't get there with flat tops and a .030 gasket. Anyone actually test this on stock size comb chambers?
Thanks
Old Sep 19, 2007 | 07:35 PM
ReeseSS's Avatar
ReeseSS
Default RE: compression ratio??
Domed pistons will not keep you under 10 to 1. Manufactures specs are pretty dead on. Youwill have to mill the heads with flat tops to get 9.8 to 1.
Old Sep 20, 2007 | 08:20 AM
mentor70's Avatar
mentor70
C/P pistons and SE has a forged pistons with a 4cc dome. out of the box with a 84 cc head i belive, is a 9.5 to 1, Im not 100% on this, but i think if you head is milled to 80 to 82 ccsit will be 10. to 1
Old Sep 20, 2007 | 03:27 PM
draycer's Avatar
draycer
Yes I've been looking at these pistons. SE rates them 9.6:1. If I use these with a .30 gasket you think I will be close?
Old Sep 20, 2007 | 04:27 PM
mentor70's Avatar
mentor70
Yes, but it would be best to have the cylinder heads CCed and equalized so you know for sure waht you have.
Old Sep 20, 2007 | 04:44 PM
Kingofcubes's Avatar
Kingofcubes
On a 98" the formula is 3.937x3.937x.7854x16.387x4=798cc's[/align]Gasket is 3.937x3.937x.7854x.030"x16.387=6cc's[/align]If head is 86cc's 86+6=92+798=890/92=9.7 to 1= flat top piston not taking into consideration the valve pockets (1cc approx.)[/align]This is about as close as you can get w/o actually oiling it out.[/align]So 10.2 to 1 would be about right with a 3cc dome.[/align]So for every .040" you take off the heads you go up .6 compression[/align]Hope this helps[/align]
Old Sep 20, 2007 | 05:11 PM
draycer's Avatar
draycer
Thanks this helps alot!!
Old Sep 20, 2007 | 09:17 PM
mentor70's Avatar
mentor70
ORIGINAL: Kingofcubes
On a 95" the formula is 3.937x3.937x.7854x16.387x4=798cc's[/align]Gasket is 3.937x3.937x.7854x.030"x16.387=6cc's[/align]If head is 86cc's 86+6=92+798=890/92=9.7 to 1= flat top piston not taking into consideration the valve pockets (1cc approx.)[/align]This is about as close as you can get w/o actually oiling it out.[/align]So 10.2 to 1 would be about right with a 3cc dome.[/align]So for every .040" you take off the heads you go up .6 compression[/align]Hope this helps[/align]
Good info, thanks KING!
lt1tyrell
Aug 22, 2011 10:00 PM
troop
Feb 19, 2010 05:23 PM
Rebel78
Dec 19, 2008 03:41 PM
gpp
Nov 7, 2007 08:27 AM
valkal
Sep 13, 2007 10:29 PM
