Screaming Eagle Performance exhaust
Old Dec 28, 2005 | 12:32 AM
capt42a's Avatar
capt42a
Default Screaming Eagle Performance exhaust
Hello All,
I'm buying a set of Screaming Eagle performance mufflers from a fellow member (jeepster09). How do the SE performance exhaust sound compared to the touring mufflers ? Any tips on the install on my 06 FLHT/I ?
Thanks for the help.
capt42a
Old Dec 28, 2005 | 12:39 AM
Terry TK's Avatar
Terry TK
Big Kahuna HDF Member
Default RE: Screaming Eagle Performance exhaust
You will notice a big difference in sound. Not too loud but louder than you are used to. They will have a much deeper rumble and should up your performance a little. What other mods have you done? Install is easy. Remove saddlebags and unbolt everything from the rear of your header to the bottom of the saddlebag brackets where the mufflers bolt on. Sometimes the stock mufflers are stuck on pretty good so once you get the muffler brackets all the way off (don't just loosen them) front and back then try twisting from the rear of the bike. Work them back and forth until they come off. I use a little silicone sealer when I attach the mufflers back on the header. Just put a ring of silicone around the rear of the header, slide the muffler on and make sure to clean off any excess. Line everything up and make sure the mufflers are even at the rear. Tighten everything down and then most important: CLEAN ALL FINGERPRINTS OFF THE MUFFLERS AND HEADER BEFORE YOU START THE BIKE.
Have Fun
[sm=biker2.gif]
Old Dec 28, 2005 | 11:30 AM
CHEYENNE's Avatar
CHEYENNE
The SE SLipons are a great sounding exhaust. I had them on my SG and loved that I could cruise at 80mph and still listen to my passenger/radio, but when getting on it they would also rock.
Old Dec 29, 2005 | 07:39 PM
hobojo1's Avatar
hobojo1
I am putting on a set of the SE Pro Performance mufflers on a new Ultra. I am glad to hear that they are louder than the stock mufflers. I enjoy the SEII's on my 02 Standard. I am also putting a Power Cmdr and the A/C kit on the Ultra. Can't wait to get into the wind......Even though it will b cold........
Joe
VA Beach[IMG][/IMG]
Old Dec 30, 2005 | 12:11 AM
capt42a's Avatar
capt42a
Thanks for the reply's, and tips. terry1955, I haven't done any mods other than mounting a detachable king tour pak. No engine mods yet. I plan on checking on the Harley download (stage 1 or 11)after putting the new exhaust on and I'd like to add a radio in the near furture. I'm trying to cut costs as much as I can. My other half doesn't appreciate or understand my need to change the FLHT/I from stock.
capt42a
Old Dec 30, 2005 | 06:03 PM
jeepster09's Avatar
jeepster09
John
You will love them....I know I do....if it wasn't for that damn horsepower addication I would not of taken them off. They not only look good but sound awesome. I will probelly regret the ugliness of 2 into 1's and want to guy them back from you.[lol] [sm=icon_cheers.gif]
Old Dec 30, 2005 | 06:07 PM
jeepster09's Avatar
jeepster09
Another good simple mod would be to change your compensator gear ratio to 3:31 by changing clutch basket and compensating gear. If you do this put in the automatic chain tensioner at the same time. It gives you alot more snap and does not effect speedo reading. It only moves rpm's up by around 600 or so, but it makes a big difference in acceleration.[sm=biker.gif] It will set you back about $400 to do give or take depending if you can do or if you shop around.
Old Dec 30, 2005 | 06:54 PM
MegaHDman's Avatar
MegaHDman
ORIGINAL: jeepster09
3.37 gearing for a touring bike is a good idea, especially if he has a SE 6 speed or something similiar with an OD top gear. Auto primary chain tensioner, though is NOT a good idea(especially the aftermarket units like the M6 from Hayden and HB-125). The manual tensioner is the best bet. Lowest parts count which means less to go wrong, and the primary should be inspected every few thousand miles anyway. Auto tensioner just allows another part of the bike to be neglected from lack of service.
Old Dec 30, 2005 | 07:09 PM
jeepster09's Avatar
jeepster09
ORIGINAL: MegaHDman
I have had the Harley Automatic tensioner for several miles without any problems, plus they are coming as original equipment now on 06 Dyna's. I guess I disagree, if Harley is putting tensioner into production bikes I think they should hold up just fine. Of course you still need to change fluids at regular intervels.
tooch69
Jul 19, 2017 04:42 PM
purvissp
Mar 23, 2010 07:51 PM
bob2002
Jan 25, 2008 08:16 AM
Pascal
Jun 22, 2007 10:20 PM
aframe2
May 23, 2006 11:09 PM
