I was able to pound/bore through the cats (the catsare a soft aluminum type screenmaterial about 1.5" thick) using a 1.5" diametergalvanized pipe (make sure it fits into the muffler inlet and the pipe is not real thick walled). I cutthe pipe at a 90 degree angle toabout 18' long. Thenwith a bench grinder,sharpened the end of the pipe, real sharp. On the other endof the pipe Idrilled two 1/2" holes across from each otherandpushed through, and bolted down, a 12" longbolt to form a "T" handle. Once completed, I put the muffler on the gound with the inlet side facing up. Make sure you use some thick carpet or paddingas a cusion for the outlet end. I inserted the sharp end of the pipe into the inlet (this is where the cat screen is) I used small sledge hammer to pound into the cat material. I periodically sprayed in WD40 to provide lubrication. Every few pounds I use the "T" handle to twist around the pipe so it didn't get lodged into the material. After about 5 minutes or so of pounding and spinning I broke through the material. Since I had been makeing sure the pipe wasn't lodged in the material,I was able to pull out a perfect "plug" of cat material. Once out, there was a perfect, clean 1.75 (approx) hole straight thourgh the cats.
Once done, I was very pleased with the performance and sound of the muffler. It was a little bit louder than before with a nice growl when ramping up.
I know other people have done the same thingusing a concrete boring bit. But I priced it out, and it was like $50 for the part. I just lopped the pipe of my volley ball net posts.
Hey Pumba11 ... after I read your post about how you creatively removed the catalyst material from your '06 CVO pipes I got inspired to try it myself for my '08 CVO SEUC. First step was to find someone else's take-off mufflers so I could preserve my own (just in case!). I found a pair on Craigs List for only $50 from an '07 CVO SEUC and snapped them up ... then the next step was to find a way to cut through the catalyst material since I didn't have a convenient volleyball pole lying around! So, I went to Home Depot and boughtthe deepest1 5/8" hole bit (for metal of course) and a long extension so I could get into the inlet part of the pipes.After discovering that I didn't have any WD-40 around, Iraided the pantry for some olive oil which worked to keep thehole bit lubricated. Even with a simplehome cordless drill, after about30 minutes I had perfect"plugs" of catalyst material pulled from both pipes!
This weekend I willslip these on the scoot and see/hear/feel the results. Just curious ...mybike is one of those "closed loop systems," do you have to do anything elseto tune the bike once your cats were out?
Luckily I have a carbed bike and a tweek on the enrichment screw was all I needed. I have already jetted the carb formy SE mufflers I had on before these, so it didn't take much.
I am very please with the mellow sound I have gotten out of mine. Still in rush hour they arelittle too quiet. But MUCH better than the stockers that came on my bike.
I hope you enjoy them and let me know what you think after you ride them.
Well, since Pumba11 is a traditionalist with a carb I have to ask for other advice ...
Can I just slip on the mufflers that I drilled out the catalyst material onto my '08 SEUC ... or do I have to arrange for some tuning of the air/fuel mixture? I am not mechanically inclined, and have never had a "closed loop system" with O2 sensors! Any help certainly appreicated!
Thanks ... since I don't plan to change the air filter right now I went ahead and slipped the "catalyst free"pipes onto the scoot today. Unfortunately, it started to rain about the time I was finishing up so I haven't road tested the sound and performance yet ... but sitting in the garage at an idle the pipes are definitely a lower (deeper) rumble tone but only a slight bit louder than stock - which is exactly what I was hoping for. Revving the engine up gives a nice bark without being hard on the ears. So far, I am pleased with the results but the real test will be highway speeds. The rain isn't supposed to break here until the weekend, so it will be a few days before I know if they will stay on! All told, my $70 investment seems to be working out just fine ... andfor now at least, I get to keep the stock look of the CVO SEUC with a more authentic Harley rumble!
