Bike Stalling when taking off from stops. Help!
Old May 30, 2008 | 01:14 PM
SloChicken's Avatar
SloChicken
Default Bike Stalling when taking off from stops. Help!
Just loaded my bike to go out to Palm Springs with my girl. We just pull out the driveway and the bike idles a bit erratic, and then when I twist the throttle open it stalls. This happens every time I try to start out; the bike idles, then when I give it gas, it stalls.
To me it seems like a fuel isssue as the spark is there to help it at idle. I disconnected my PC3 thinking it may be that, but it still did the same thing directly routed to the bike. I hooked it back up, and still the same, so it isn't that ...
I am stumped, I think it is either ECU based, or Fuel delivery based, but I could use the diagnostic help.
So I come here to you all, looking for a bit of experienced opinion.
Any ideas?
Thanks, I will look at this post when I get back in a couple of days,It looks like I am caging it until then ...
Old May 30, 2008 | 01:16 PM
SloChicken's Avatar
SloChicken
Default RE: Bike Stalling when taking off from stops. Help!
Yes, it has gas in the tank, I just put in about 3 gallons to fill it. I am HOPING it isn't DIRTY FUEL ...[:@]
I took off the gas cap while it was idling to see if it may have a vapor lock impeding fuel delivery, but that wasn't it either.
Then I pushed it up my hill...
Phaakkkk!!![:@]
The bags are in the cage and my girl is ready, so. I guess I will have to enjoy the A/C ...
Old Jun 1, 2008 | 03:48 PM
SloChicken's Avatar
SloChicken
... Gone all weekend and nobody had any thoughts on this???
If anybody does, feel free to post up.
BTW the bike is a FLHTI injected Electra Glide with a stage one and a power commander 3 USB. that is it.
Old Jun 1, 2008 | 03:57 PM
DrSmaggs's Avatar
DrSmaggs
I have yet to hear of such an issue. if it started happening just after a fuel stop, I'd say it's bad gas.... it happened to my SUV once. I drained the gas and refilled and BAM, she ran smooth!
Old Jun 1, 2008 | 04:17 PM
Randall's Avatar
Randall
Id pull the fuel out of the tank and lines, as much as you can get rid of. check on any filters and see if the inside of the tank looks clean or if its possibly rusted anywhere or inside coating is peeling? Possibly bad gas or slow flow in the lines from restriction. giving you just enough fuel to keep it idling but not enough for take off power. I know that just this year on my 2005 FLHRSI I noticed the inside of the tank had a coating from the factory that seemed to be peeling off slightly around the filler hole. Not sure if that will help you, but thats where I would start. Cheap and easy attempt anyway. Good Luck
Old Jun 2, 2008 | 12:21 PM
LawrenceFromTorrance's Avatar
I'm from the cause and effect school. What did you recently change? For example did you just start riding after it sat for a while (bad gas), did you just fill up and it started happening (bad gas), did you and/or your girl friend recently gain a lot of weight, was it running really well before you noticed this or was it gradually starting to run poorly, etc?
Old Jun 2, 2008 | 11:32 PM
SloChicken's Avatar
SloChicken
so far, the best I have is that I left my ignition on and it drained the battery. It was at 11 volts when I was going through my diagnostics. it is charging now. we will see how it does in the morning.
Then it will be on to finding out why my battery was low on its charge.
Old Jun 4, 2008 | 03:34 PM
SloChicken's Avatar
SloChicken
Charged battery, it was at 11v,
checked and applied dielectric grease to ignition and fuel electronics.
put it back together and viola!
Potatopotatopotato
So yeah, it was one of those interventions - kind of a shotgun approach, but it worked.
Justickled t'wasn' sum stoopid elektruniakul kumponunt, er sumpin'nuther, 'er watnot n such ...
matte
Aug 12, 2016 09:17 PM
Hector Montero
Jul 31, 2014 02:07 PM
wodom1
Jun 12, 2010 10:57 AM
wyoming55
Jun 6, 2009 09:18 AM
Momentor
Sep 24, 2007 06:29 AM
