This is the first problem I have had. When coming home from work I noticed she was running a little sluggish after the first 5 miles. It was about 85 and humid today, in the 90's yesterday and she ran great. Running at 80mph and twist the throttle the pull I am use to wasn't there and then when I was going up a hill I had the throttle pegged to the stop just keeping steady at 80 in sixth at 3000rpm.
I have V&\\;H true duals with Rush slip-ons with stock air cleaner (these have been on for over a month), I just replaced the plugs and oil last week. Oil pressure was fine, 93 octane fuel, tires at correct pressure and brakes are not dragging. [/align]
The "problem du jour" on the '08 tour bikes seems to be the fuel filter canister, which might be giving you your problem. \\; Do a seaarch on it and check the posts in the touring forum. \\; Short version: \\; the fuel filter in the tank is breaking apart and the bikes aren't sucking fuel when this happens.
The "problem du jour" on the '08 tour bikes seems to be the fuel filter canister, which might be giving you your problem. \\;\\\\\\; Do a seaarch on it and check the posts in the touring forum. \\;\\\\\\; Short version: \\;\\\\\\; the fuel filter in the tank is breaking apart and the bikes aren't sucking fuel when this happens.
Let us know how you make out. \\; If money isn't the issue, you might want to change out the stock AC for a stage 1 and get some sort of fuel management setup.....or the IED's and a download.
Let us know how you make out. \\;\\\\\\; If money isn't the issue, you might want to change out the stock AC for a stage 1 and get some sort of fuel management setup.....or the IED's and a download.
What a day, went by the dealer and talked to service, all I could get out of \\;HD's #1 dealer was bring it in and we will check it out, BTW we are two weeks out on appointments then there is a four to five day wait. Well I made it out to the garage and pulled the fuel cap, sure enough I seen fuel sprinkles and can hear dripping. I'll call around tomorrow to find a canister. I know I should have bought one today but I was running late to an appointment, mine don't have four - five days like the dealers.
Dawg: I have the filter and saving up for the power commander which I should have soon. Your post on replacement have been very helpful.
I have posted on four HD forms and not once have anyone said come back in two weeks and wait 4 - 5 days. This is what a family is like. I wish the family of dealerships would start understnding this.
Thank you all very much
