Fuel Line Leaking
Old Mar 16, 2006 | 08:55 AM
HarleyRiderOrlando's Avatar
HarleyRiderOrlando
Stage I
Default Fuel Line Leaking
I have 2 fuel lines leaking on my 01 RK Classic and need help with how to properly drain the gas tank and how best to get to the fuel lines under the tank, hopefully without removing the whole tank.
Old Mar 17, 2006 | 01:32 AM
vernh59's Avatar
vernh59
Default RE: Fuel Line Leaking
If you have the service manual it will take you through that step by step. It is a GOOD investment. On my 02 FLHR there is a vacuum petcock. Take the fuel line loose at the carb and position something to catch the fuel. Remove the vacuum line from the petcock and apply a vacuum pump to open the petcock. The fuel should drain. If you are replacing the line from the petcock to the carb all you need to do is turn the fuel off at the petcock. If you are replacing the crossover I think you need to drain the tank. You shouldn't have to remove the tank. Hope it helps.
Old Mar 18, 2006 | 09:56 AM
Uncle Peepers's Avatar
Uncle Peepers
Ditto on the service manual; since you have to dis-connect the cross-over tube to drain the tank, you may as well go ahead and remove it. It's really not that much of a job. BTW, make sure both of your fuel lines are properly seated in the tank fittings before you tear into it. There's always a chance that that is the only thing wrong.
Uncle Peepers
cptseawolf
Feb 26, 2017 03:49 PM
High Roller
Mar 14, 2015 07:07 PM
baldeagle503
Mar 14, 2014 09:34 PM
BlackHwk27
Aug 2, 2009 10:27 AM
Johneb48
Oct 19, 2005 09:40 AM
