View Poll Results: Which Exhaust?
Fat Cat
20
71.43%
Rinehart 2-1
28.57%
Voters: 28. You may not vote on this poll
Exhaust Options
Old Dec 15, 2008 | 08:16 PM
beaureed445's Avatar
beaureed445
Default Exhaust Options
Ok, so I'd like to thank everyone who answered all of my questions, and helped me reach this point with my 103" correction. Here's my parts list....103" SE Flat Tops, SE Heavy Breather, SE Billet Cam Plate, PCIII, TW6G-7 cams, S&S Gears, Baisley Super Stock Heads....Don't know which exhaust to run with....either a Fat Cat (quiet baffle for TQ), or Rinehart 2-1. Suggestions?
Old Dec 15, 2008 | 08:54 PM
WARG's Avatar
WARG
beau, I'm going with the D&D Fat Cat. They look good, perform great, and they are local to Fort Worth,TX, which is close for me.
Do you already have the 103 build? What's the story with the correction?
Old Dec 15, 2008 | 09:04 PM
beaureed445
Yeah, I already have the 103" installed. I did it before I knew about the wisdom of the HDF members. I listened to the dealer, and did the 103" flat tops, bored my stock cylinders, didn't change push rods, and didn't do any headwork. However, I didn't listen when they said that I didn't need a fuel management system. They were trying to sell me another download, but I opted for a PCIII. It makes 84 hp, 104 lbs tq. Pulls really hard, but cam dies at about 3700 rpm. I'm going to the TW6G-7, which is the exact same as the TW6-6, only in a gear drive.
Old Dec 15, 2008 | 11:11 PM
TXCHOP's Avatar
TXCHOP
See if the lowcat is availible for your bike. The regular FC will not work well with a lowered softail. The lowcat is the same pipe, but the muffle can is upswept a bit.
Old Dec 15, 2008 | 11:21 PM
WARG's Avatar
WARG
Really!!! I thought the Boarzilla was the only one made with the upswept muffler. I was wondering about draging the pipe on turns since my rearend is lowered. I will check this out as well.
beau, does the PCIII work well with your build? I have a PCIII as well and was wondering if it will be adequate for hotter cams and eventually a big bore kit.
Old Dec 15, 2008 | 11:28 PM
TXCHOP's Avatar
TXCHOP
Here you go...pretty new to the market...
http://www.danddexhaust.com/catalog/2008/06/53831.htm
Old Dec 15, 2008 | 11:52 PM
WARG's Avatar
WARG
thanks, I think I like the regular style better for a fatboy. Hopefully lowering my bike an inch won't matter too much.
Old Dec 16, 2008 | 04:55 AM
hpfatboy's Avatar
hpfatboy
Talking
V+h pro- pipe all the way!
Old Dec 16, 2008 | 05:41 AM
lionsm13's Avatar
lionsm13
Kerker 2-1 for me. They were/are standard issue on a lot of your Big Dog Choppers, and a lot of guys took up off to put on those fugly groundpounders. What's better, is you can buy off ebay for a buck and a half or so... Not so with the other's.
BTW, I think that the V+H pro pipe is fugly too, along with the boarzilla.
The fatcat is ok though, had heard some issues with their baffle coming loose a while back, don't know if that's the case anymore.
Old Dec 16, 2008 | 05:52 AM
hpfatboy's Avatar
hpfatboy
Thumbs down
lionsm 13 , were not here to knock each others opinions, were here to give opinions. dont appreciate you calling my pro pipe f__king ugly!!!!!!
