piston ring question
Old Jan 16, 2009 | 10:24 PM
Newhawk's Avatar
Newhawk
Default piston ring question
Here is the scenario. 95" motor with only 4000 miles on it. SE211 cams.
Indy says motor losing compression because of the HD cookie cutter build. He says rings are gaped too wide. Wants to replace the rings with some 5 over for 1550 motor. No mention of honing the cylinders.
1. Would you replace rings without honing the cylinders?
2. Would you replace rings when the engine hasn't been opened and someone only thinks the ring gap is too big because the the HD did it thing?
3. Can it be determined what might cause a low compression without opening it up?
4. Would you go to another mechanic before proceeding?
Thanks for any insight. I hate hindsight.
Old Jan 16, 2009 | 10:46 PM
kansasroadking's Avatar
kansasroadking
1. absolutely not
2. no
3. yes, with a proper leak down test, done correctly.
4. yes
211 cams have a 45deg. intake closing and 40deg. overlap.... you will loose some ccp unless it has 10.5 or 11:1 mechanical comp ratio.
Old Jan 17, 2009 | 01:55 AM
FXSTDSE2's Avatar
FXSTDSE2
Let's see. SE 95 with a 211 should make about 170 CCP at sea level. Subtract for 6000 feet of elevation in CO Springs and you should have 140 with a 6% margin so if your compression is in the 130 range there shouldn't be a problem.
What is strange is Chazmanian posted the exact same build with CCP of 130 also living in Colorado. My personal opinion is there is nothing wrong with the bike. Swap out the cam with a intake closing of 30-36* SE 203 or 204, Andrews 21 or 26 or a crane 1-3000 or 1-3001 and be happy. The SE builds are built all the time and the ring gaps are probably within specifications.
Old Jan 17, 2009 | 07:23 AM
Dalton's Avatar
Dalton
1. Would you replace rings without honing the cylinders? .005 over rings are designed to work in cylinders that are bored .005 over. No, I would not do this.
2. Would you replace rings when the engine hasn't been opened and someone only thinks the ring gap is too big because the the HD did it thing? Without doing a compression and leakdown test, to arbitrarily make this statement the ring gap is too big is wrong. No, until I knew exactly what , and if there was an isue I would not replace the rings.
3. Can it be determined what might cause a low compression without opening it up? See answer to question two.
Absolutely if you have told us the whole story, these shot in the dark, shoot from the hip diagnosis will do nothing but cost you money and may not fix your problem.
See above.
Old Jan 17, 2009 | 08:09 AM
txtec's Avatar
txtec
Default compression
my 06 fxd is a 95 with 211s, s.e. flatops,.030 cometic,stock heads,ccp is 177front,180rear.350 feet above sea level.
Old Jan 17, 2009 | 07:54 PM
Newhawk's Avatar
Newhawk
Thanks for the info.
Seems to be some confusion about whether it is losing compression (large ring gap story) or just insufficient compression to begin with.
I think a leak down test somewhere else that know nothing about what the situation and see what comes of that.
BTW, it is not my bike.
Old Jan 17, 2009 | 08:24 PM
FXSTDSE2's Avatar
FXSTDSE2
What's the alleged compression?
Old Jan 18, 2009 | 03:38 PM
Pixs's Avatar
Pixs
Hi Newhawk,
FWIW, I agree with the advice you are getting here. However you may want to have a look for yourself. I can't vouch for the quality, the price is right, probably Okay: http://www.harborfreight.com/cpi/cta...emnumber=94190 . Learn to use it and have some fun figuring things out for yourself, I'm sure that there are many members here and on other boards that will be happy to help you gain the knowledge you need.
Old Jan 21, 2009 | 02:34 AM
Big Jay's Avatar
Big Jay
4th Gear
Do a true leakdown test and see, if it is in fact, leaking.
Jay
Old Jan 21, 2009 | 06:12 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Smile
We have been doing Harley engine work/mods for 27 years.
Your mechanic must be the second coming of Houdini, to be able to alert you to all that info without testing procedures.
I want to get a pair of those goggles he has!
Cheers,
Scott
