Wondering what the average temp people are getting for the stock 96". I have an 07 with oil cooler and getting readings as high as 230. I was told by HD that the later engines run hotter and this is the norm.
man i hear ya. check out nightriders.com they explain pretty much what the issue is. hd has the fuel air ratio set @ 14.8 to 1 which is super lean causing the bike to run hotter. reason has something to do with cleaner emmisions.
Late engines run hotter cause the tuning sets the A/F ratio almost everywhere on the map at 14.6. This is the closed loop. The EPA requirements force this. Nothing HD can do except desigh good parts. There are a few areas where this is wanting. Cilenders for 110 one area.
These things are adjustable using various methods. If I didn't have so much in SERT I would look at TTS Mastertune or Zippers Thundermax. These are the Cadilaces of tuners but pricy.
After much work, my oil temp on a 85 degree day is about 200 deg.F with fairly hard ridding. And plugs look just right. No soot at the exhaust.
From my own experience bone stock with a calibrated gauge my softail ran 250 most of the time in normal riding conditions on a hot day cruising with no cooler. Later addition of tmax brought it down to 220 which I feel is the perfect oil temp. I no longer get excited if on a rare occaison in city traffic if I see 250 as it is now an exception rather than the rule. Bone stock I saw 300 once but had synthetic in it. Your reading of 230 if accurate is nothing to get bent out of shape about as it is deemed normal in many circles.
Ron
230 on the 96" is not bad at all. The routinely run 250 plus and 280 or more is not uncommon in stop and go conditions and high ambient air temps.
With a good tune it is entirely possible to have an engine that will normally run 205 - 215 , hotter in stop and go but not anywhere near the temps you will see on a stock bike.
Tune is the key - proper ignition timing and air/fuel ratios.
All the newer HD's should have oil coolers. A big generous cooler. At a certain point function has to be above form.
As many as needed or as big as needed to get oil temp 195 on a hot day. Especially the baggers.
You can thank the EPA for all this. With stricted emmisions, Harley sets the A/F in cruising range a 14:6, way to lean IMO but it is what it is. Harley did answer by putting parade mode in hte ECU, which means that when the bike is hot and at lower RPM's the ECU will shut the spark off to the rear cylinder. Works OK but the bike still runs hot. Harley's answer for the '09 touring bikes was to run the rear exhaust under the frame rail for the left side discharge. Keeping it away from your left leg. You CAN change your air/fuel ratio with a Super Tuner. WHen I dyno tune I usually turn the parade mode off, calibrate the bike at 13.2 air/fuel and set the air/fuel to 14.2 for the cruising RPM's and thrpttle position and 13.2 - 13.6 air/fuel for the 80 and 100 percent throttle positions.
Well, it's normal. But that doesn't mean it's not bad.
I think you misunderstood my post - I dont at all like a bike that is running 250+, it is too hot and due to lean settings from the factory. 230 is not bad, and lower than that by 10-15 degrees is good.
