knocking sound
Old Apr 13, 2009 | 04:56 PM
mikewatts's Avatar
mikewatts
6th Gear
Default knocking sound
Hey guys, ive got a twin cam 88 with 6000 miles on it. i'm geeting a small knocking noise comming from the engine when its at idle.. its not constant but definatly noticible>>
Old Apr 13, 2009 | 08:08 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Check your compensator sprocket nut.
Old Apr 14, 2009 | 11:08 AM
1711tab's Avatar
1711tab
Check TQ. on Comp. Sprocket Nut and check for loose exhaust brackets...
Old Apr 14, 2009 | 06:43 PM
mikewatts's Avatar
mikewatts
6th Gear
awesome , thanks guys i will check that out, i appreciate the help!!!
Old Apr 15, 2009 | 08:24 PM
tgaetto's Avatar
tgaetto
Yes comp sprocket! I was amazed at the results!
Old Apr 16, 2009 | 06:02 PM
joearizona's Avatar
joearizona
I've also have the knocking at Idle, I have locked the compensating sproked in before & it did the trick. I'll be doing a super service this weekend & I have the knocking noise again, the last time I noticed the sproket had some wear on the curved section, if it's any worse I'm going to not ride her until i can get a new compensating set up.
doc308
Shovelhead
Sep 20, 2019 12:32 PM
1998fxd
May 20, 2012 12:51 PM
wolfprint
Oct 28, 2011 10:19 AM
Misfit Tank
Feb 20, 2011 05:17 PM
pino56
May 20, 2008 04:35 AM
