Too much fuel consumption - NEED HELP
Old Sep 30, 2009 | 08:13 PM
bombero911az's Avatar
bombero911az
Stage IV
Default Too much fuel consumption - NEED HELP
Hi, I'm new to this forum. I need help. I have a 2007 HD RK Clasic with V & H true duals. I have noticed in the last couple of weeks the exhaust smells really heavy as if it is burning too much fuel, and I am using more fuel than before. In fact, I ran out of gas 3 days ago when I misjudged my reserve gas light warning (The light went on for only 20 or so miles).
I have 24, 000 miles on my bike. I did the 20, 000 mile service and its almost due for 25,000. I have not changed the fuel filter yet. I do have a service manual but I dont have the diagnostic manual that indicates fuel troubleshooting. Before the 20000 mile service I did, I had Harley dealership do EVERYTHING. They installed the V & H pipes.
I need assistance with suggestions on what my problem is. Is it the filter? Some sort of sensor? Can the fuel pak that HD installed go "out of tune"? The installation was when I first bought the bike, less than a 1000 miles in it. Does anyone have or know what the 2007 diagnostic manual says?
Thanks for all your help! I think this is a great web site!
Old Sep 30, 2009 | 08:19 PM
tmitchellof PG's Avatar
tmitchellof PG
What kind of gas mileage are you getting?
Tom
Old Sep 30, 2009 | 08:34 PM
bombero911az
Stage IV
now....im getting about 28 miles to the gallon.
Old Sep 30, 2009 | 08:50 PM
Shovelhead Bob's Avatar
Shovelhead Bob
What kind of EFI Management device are you using????
Are the o2 sensors still installed???
BTW, Welcome aboard... please take a moment to introduce yourself in the NEW MEMBERS forum....
Old Sep 30, 2009 | 09:04 PM
bombero911az
Stage IV
Both the front and rear sensors are there and tight. When I clean and wash the bike around the sensors, I try to take care not to damage them since I know they can get expensive and are delicate.
The dealer installed the pak....I ordered the V & H through the dealership. I m not sure what EFI management device they installed, where is it located so I can look? I looked at the reciept and they did not label it on there....
THX for the help so far.
I will post something in the intro shortly!!!
Old Sep 30, 2009 | 09:12 PM
Shovelhead Bob
If you do have an EFI management device, it will be attatched inline of the harness and ECM, or a program loaded into the ECM....
V&H endorses the FuelPack, it is a funny little box with LED digits, PC is a slightly larger box with 3 buttons, and a green LED light bar...
Let me clarify something... After the pipes were installed is when the mileage went in the crapper, am I correct????
Old Oct 1, 2009 | 04:43 AM
jkoch09ultra's Avatar
jkoch09ultra
Check tire pressure and make sure the air cleaner is clean. These will kill mileage quick and are easy to fix.
Old Oct 1, 2009 | 06:05 PM
bombero911az
Stage IV
Thanks for all your replies. After the pipes were installed, 23000 miles ago, I only felt a slight difference. This problem is new, within the last couple of weeks. Tire pressure is fine. I replaced the air filter on the 20000 mile service on Jan 31, 2009.
Does anyone know how do you know if a oxygen sensor went bad? Is is a "replace-the-part-trial-of-error" way of finding out? Or is there some sort of tool/device that can "measure" to see if it is working?
Last edited by bombero911az; Oct 1, 2009 at 06:07 PM. Reason: forgot to add a sentence
Old Oct 1, 2009 | 08:00 PM
60wt's Avatar
60wt
Have you been making frequent short trips some where??? My mph went down to 28mph when I started to ride it to work 1 1/2 mile...had me going, thought something was wrong, turned out to be the frequent short trips...high way about 40...just a thought..
Old Oct 2, 2009 | 05:38 PM
priceamp's Avatar
priceamp
Besides the exhaust “smells really heavy”, have you noticed any change in the way the bike idles, accelerates or how it runs at a constant speed?
It is possible that your fuel management system has lost it’s programming or the programming got corrupted or the connection between the fuel management system and the ECM has changed due to loose wires or corrosion.
I would pull the plugs and see how they look to verify that the bike is running rich. I would also disconnect the fuel management system from the ECM and check the connector pins and make sure they are clean and making a good connection.
Else as previously stated, a change in your riding style will affect your gas mileage. My gas mileage drops a little in the winter months when Oregon uses 10% Ethanol.
Lady-K
May 24, 2023 09:12 AM
Trevor Cornejo
General Topics/Tech Tips
Nov 13, 2017 10:05 PM
knoren
Nov 4, 2010 10:12 AM
kennyjohn
Jun 15, 2010 05:14 PM
ENGINE5
May 10, 2009 11:01 PM
