torque cones question
Old Nov 5, 2009 | 12:58 PM
riskyfool's Avatar
riskyfool
Default torque cones question
What is the proper order - cones, gasket, pipes or gasket, cones, pipes?
Looks like it can go either way.
Old Nov 5, 2009 | 12:59 PM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
Gasket cones pipe.
Old Nov 5, 2009 | 01:01 PM
1931jamesw's Avatar
1931jamesw
Originally Posted by HarleyGoodies
Gasket cones pipe.
Yep...
riskyfool's Avatar
riskyfool
Thanks very much!
Old Nov 5, 2009 | 01:27 PM
rob71458's Avatar
rob71458
Sorry, I disagree. Cone, gasket then the pipe. How else will you get a seal between the pipe and cone? When done the way I recommend the gasket will seal the pipe to cone and the crushed gaskets outer edge will seal the port so that nothing gets by the cone. Actually the more I think about it both ways may work, but by putting the gasket in after the cone there will be no way the gasket can crush and block the port.
Old Nov 5, 2009 | 01:43 PM
SamStone's Avatar
SamStone
Do torque cones really give you more torque? Do they change the sound? Do you run them with or without baffles? Do they work with slip-ons?
Old Nov 5, 2009 | 03:00 PM
qtrracer's Avatar
qtrracer
Proper order is gasket, pipe, then torque cone in the trash. Sorry if I said it too harshly but how will choking off your head pipes help anything? Everyone talks about getting the proper gasket to put in the head for the exhaust so it wont crush into the exhaust flow. Be prepared to take'm right back out.
Old Nov 5, 2009 | 03:24 PM
rob71458's Avatar
rob71458
I have used torque cones in the past in a bike that did not have the best combination of parts and it did help a lot. They are probably best for bikes with straight pipes etc.
Old Nov 5, 2009 | 03:33 PM
qtrracer's Avatar
qtrracer
Yes that would be a use for them in that case that you spoke of. However I would just be considering that a band-aid on a problem that needs to stitched up.
Old Nov 5, 2009 | 03:59 PM
rob71458's Avatar
rob71458
Exactly, maybe a band aid or a cheap way for someone to gain some torque. I have an old set I will donate if someone wants to give them a try.
