SE 255 Compression ?
Old Dec 19, 2009 | 07:42 PM
connector's Avatar
connector
Default SE 255 Compression ?
Taking the bike in on tuesday for a build here is what i'm doing
-255
-High comp pistons 10.5
-New jugs
-JR racing heads
And a few other things to compliment the ride, now my question is for this cam, is 10.5 too much? I have read a lot of posts and i don't see others with this combo (10.5 -255). My builder says it will work great with a good tune.
Thanx in advance
Old Dec 19, 2009 | 07:50 PM
Barney Biker's Avatar
Barney Biker
From what I have read on these boards that may be too much. I wouldn't go over 10.0 with the sorry gas we have now days.
I have the SE 255 in my stock 96 and like it a lot.
Barney Biker
07 EG
Old Dec 19, 2009 | 08:06 PM
producer's Avatar
producer
Barney Biker
07 EG
Yeah, 10.5 would be a bit high because the intake closes 9 degrees sooner than the SE203 cam. I've seen bikes with 10.5:1 running 203's. You could get away with this but it would be risky without running your squish on the low end of the safe zone and 92+ octane gas. Heat would be an issue possibly too. However the torque might be a lot of fun! It would run pretty good in cooler weather.
Old Dec 19, 2009 | 09:28 PM
beaureed445's Avatar
beaureed445
Personally, I would pass on the new jugs, and have your stock jugs bored to match the pistons.
Old Dec 19, 2009 | 09:33 PM
BoomerBob's Avatar
BoomerBob
At 10.5 I hope you're putting compression releases in.
Old Dec 19, 2009 | 10:41 PM
connector's Avatar
connector
Manual comp release, for sure
Old Dec 20, 2009 | 09:03 PM
hommes's Avatar
hommes
Default ok, here we go...
On a 96 with slip ons, stage 1 and SE air cleaner the estimates for HP on this forum have been 77 hp.
Let's say this is accurate.
Now, lets say we're gonna do HD cams only ...starting from the mildest cam and going up to the largest cam feasible for a cam only upgrade. What would the corresponding HP increases be for those different cam?
Also, what would be the number of work hours involved and prices for the work at the dealer and at a really good indy be?
Old Dec 21, 2009 | 10:42 AM
Old Gunny's Avatar
Old Gunny
HD has two cams people don't look at a lot that, if I was gotta restrict myself to just HD, I would check out.
Especially Connector. Be a lot happier engine. Just me though.
SE-251
SE-257
Old Dec 21, 2009 | 03:22 PM
connector's Avatar
connector
Thanx will have another look, as i'm limited to hd for now
Old Dec 22, 2009 | 08:37 AM
Bad Disposition's Avatar
Bad Disposition
Default 255 Compression
Connector,
Waiting to be used. If you are looking for a good price PM me. I liked them when they were installed in my Ultra. I'm sure you will like them in your RG.
Phil
