Upgrading my 95"
Old Dec 27, 2009 | 06:49 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Without knowing more info about the engine, it is very hard to make a good recomendations in regards to a power up-grade.
The OE 95" kit is lack-luster at best, and no wonder you are in search of more.
Scott
Old Dec 27, 2009 | 01:00 PM
KumaRide's Avatar
KumaRide
Your ride may not even be cammed? With your 95" you can achieve ~100 lb's of tq with 21's, no headwork, a 2n1 and a tune.
Old Dec 28, 2009 | 01:03 AM
rhuff's Avatar
rhuff
It is cammed....I have the original invoice....just doesn't list specific cam. I'll find out tues....and yes, factory 95" leaves much to be desired.
Old Dec 28, 2009 | 05:59 AM
Hillsidecycle.com
Sponsor
If I was a betting man, I'd bet, that 203's were in it.
Headwork, cam change, and perhaps bore, and that engine WILL have a new personality, if that is the case.
Scott
Old Dec 28, 2009 | 10:31 AM
KumaRide's Avatar
KumaRide
Your RK is geared a bit lower than softails which should help you get along quicker. Your goal was to spend under a $1,000. Including labor? Lets see what the dealer finds. It would be helpful if you had a dyno sheet to see what you are actually experiencing. I may have missed it, is your bike carbed? EFI? What kind of fuel management, ie dealer download, PC? Type of pipes? All this stuff matters and done correctly, collectively also adds to the fun factor. Share as much as you can about your build once you have the dealer info.
Old Dec 28, 2009 | 02:53 PM
djl's Avatar
djl
5K mile service? What year is the bike? A 95" upgrade would indicate that it's pre '07. 5000 miles seems a tad low for three year old bike.
Anyway, Kuma's correct about the lower gearing if the bike is '07 and later; however, that would be inconsistent with the 95" upgrade; it's already 96". Seems there is a disconect somewhere? Are you upgrading to 103"?
Anyway, '99-'01 HD touring bikes were available with either a carb set up or the MM EFI throttle body. The carb touring Bikes were geared at 3.15 and the MM EFI touring Bikes were geared at 3.37. In 2002 HD introduced the Delphi EFI throttle body and HD went back to the 3.15 gearing for EFI bikes, while the carb bikes continued to run 3.15 gearing as well, so all touring bikes from 2002 to 2006 have 3.15 gearing from the factory.
Hillside's bet on the 203 is probably right; that is the cam included in the Stage II 95" upgrade kit.
Djcamis
2014-2024 Touring Models
Feb 9, 2016 09:46 AM
ridedaddy
Engine Mechanical Topics
21
Dec 23, 2014 04:00 PM
Northern B
Jun 10, 2014 08:11 PM
jurgie
Feb 16, 2011 03:34 AM
LawrenceFromTorrance
14
Jun 2, 2008 07:16 AM
