Pushrods or timing?
Old Jul 17, 2006 | 11:20 PM
99FLSTF06FLSTFSE2's Avatar
99FLSTF06FLSTFSE2
6th Gear
Default Pushrods or timing?
Bike was running fine, except for a ticking from the front cylinder. Wasn't exhaust. Pulled my plugs and the front one was black and sooty, rear was normal. I was thinking I may have mal adjusted one of my front push rods, so I pulled em loose, rolled the motor to TDC and re-adjusted the rods out. When I put it all back together, the bike was real hard to start and back firing. Did I dick up my timing or my rods not adjusted all the way in? Any ideas before I tear it apart again will be much appreciated.
Specs: 1999 FLSTF Evo
S&S Super E
V&H Big shots
Jims powerglide tappets
Jims titanium adjustable pushrods
Andrews EV-27 cam
Elite 1 ignition set to single fire
Dual coil
everything else in the loop is pretty much stock(heads and valves)
Thanks for the help.
Old Jul 17, 2006 | 11:28 PM
liltrk's Avatar
liltrk
Default RE: Pushrods or timing?
Sounds like you got them too tight. Hope you didn't bend one. Make sure they are adjusted on the cam base circle.
Old Jul 18, 2006 | 10:39 PM
99FLSTF06FLSTFSE2
6th Gear
Not too tight. They spin with slight resistance after the tappets were bled down. Will look at the cam, make sure it's sitting where it's supposed to be. Thanks.
Old Jul 19, 2006 | 11:55 AM
Spectrexx's Avatar
Spectrexx
Here's the procedure I use.
1. lift rear tire off the ground
2. shift into 5th gear
3. remove pushrod covers
4. hold them up with clothes pins or rubber bands and paperclips
5. rotate rear tire until the lifter you want to adjust is at it's lowest point
6. collapse (shorten) the pushrod until it moves up and down slightly
7. extend pushrod until it just starts to touch the lifter
8. exten it further the proper amount of turns (to equal approx. .100 inch (mid range of the lifter's travel)
9. wait until you can spin it by hand easily, then torque locknut
10. move to next lifter and repeat steps 5-9
That's it.
By the way, you will probably not be able to completely get rid of the ticking, especially from the front cylinder exhaust lifter. The EV27 cam is notorious for being noisy. There are a couple ways to reduce the noise, but it's not that important. The bike will still run strong. I rev my EVO with the EV27 to 6500 rpm with no problems (of course I have different valve springs and valves). To reduce the ticking, you can press the original cam gear onto the EV27 cam; or properly set the gear lash using a different size pinion gear. Sometimes it's just the pushrod hitting the pushrod cover. You can sometimes remove some material with a file to stop it from hitting. Put your finger on the tube while it's running and you can easily tell if that is the problem.
Personally, I'd adjust them as required and leave them alone. If the ticking bothers you, get louder pipes, remove the windshield, or wear earplugs. The ticking will have no ill effects on your engine.
Old Jul 20, 2006 | 09:10 PM
99FLSTF06FLSTFSE2
6th Gear
Thanks for the tips. Will try it out.
Old Jul 20, 2006 | 11:39 PM
One_Screamin_Eagle's Avatar
One_Screamin_Eagle
The motor must be completely cold when you adjust pushrods, or they will be too long when it cools. When this happens, they can hold a valve open on startup which makes it hard to start and backfire through the intake.
Old Jul 26, 2006 | 08:38 PM
99FLSTF06FLSTFSE2
6th Gear
All done, bike starts fine and no ticking. Have noticed some back fire off the front cylinder, I'm talking fire ***** rolling out of the pipe when I roll the throttle up. I'm scratching my head now.
Old Jul 27, 2006 | 03:15 AM
chnpostal's Avatar
chnpostal
5th Gear
Could be a victim of circumstances...........have you checked for an intake leak? If the tick's gone, then that's what the symptoms point to.
WesternNSW
EVO
38
Apr 10, 2019 02:16 AM
Pinetop
EVO
33
Sep 24, 2014 10:05 PM
deleontow
EVO
17
Jun 7, 2012 12:24 PM
TheLoudOne
Engine Mechanical Topics
Feb 28, 2009 11:00 PM
Steve On 3
Jun 20, 2006 10:58 AM
