compression releases?
Old Apr 15, 2010 | 03:36 PM
djl's Avatar
djl
Originally Posted by fat15th
Thanks for the info, whats the average price diff. between manual and auto.
Forget about the ACRs, install manuals and use them. The ACRs are just another electrical component that can malfunction. Look at cranking compression, not static and if CCR>190psi, install CRs. Actually, if you have the heads off, just install the CRs; they definitely will extend starter and battery life, if you use them.
Old Apr 15, 2010 | 04:30 PM
prodrag1320's Avatar
prodrag1320
Originally Posted by ryanl
yup, you were the one... It was specifically a discussion about woods cams. And you plugged the numbers into your super duper computer program, and told me a woods 6 running at 10.2 would be a ping monster, and that you dont build street motors with that kind of compression because people in your area would flip out. Then I told you I was running my woods 6 at 10.2:1 and had no problems with it. I never heard from you again. I believe you also got the smack down from Randy AND Scott about the woods cams... It was pretty comical actually.
same computer program as scott uses,once youve accomplished 1% of what we`ve done over the years,talk,till then shut the pie hole asswipe
Old Apr 15, 2010 | 04:33 PM
ryanl's Avatar
ryanl
nice kirby, Ill bet your a wonderful gentlemen to do business with...
Old Apr 15, 2010 | 05:04 PM
oppirs's Avatar
oppirs
Damn the insults!!! I'd like to know if anyone has a conversion table for compression# to compression ratio???
My 96" S&S is displacing 230 psi & 232 psi. per cylinder. I have a hell of time turning it over at times. Otherwise smooth as silk, weird!
No compression releases, High torque starter.... At times a nasty kickback.
Thx
Old Apr 15, 2010 | 05:33 PM
07RoadHawg's Avatar
07RoadHawg
Thx
http://www.bigboyzcycles.com/TwinCamComp.htm
This might be as close as you can get on the net. If you know ccp, cam, and all the other measurements you might be able to back in to the static compression ratio.
Who built a motor with that much pressure for street use (never mind no releases)? Sounds pretty high to me. I figured 190 was where I wanted to be and 200 as a max.
Old Apr 15, 2010 | 06:06 PM
oppirs's Avatar
oppirs
nice site. I have an EVO, a twinny 96 is not the same.
It's the oil beathers on the S&S Carb adding carbon to the engine! Damn
This EVO is up there in pinging. I've run avation fuel or mix of 35% e85.
Timing is retarded on the crain highball4 a few degrees.
I DON'T WANT TO TEARDOWN THIS ENGINE!
Runs so damn good! If I add high octange by e85 ( easy in my area, cornbelt) =no ping! mileage suffers.
But I still ask the ? is there a conversion chart for #psi to ratio 12.5 to 1?
Old Apr 15, 2010 | 06:36 PM
qtrracer's Avatar
qtrracer
Thx
If you have a S&S 561 cam with a close of 40 degrees you have roughly 11.65 Static compression . You have to know the cam intake valve closing # to get close to your cr #'s , so this is a guess . If you have the 585v the numbers are different but not much 11.8 comp . But without a teardown this is a guess using 2 popular 96" S&S evo cams.
Old Apr 15, 2010 | 08:56 PM
SLPER's Avatar
SLPER
Default Off Point
Would have to say you're off point there...
I don't think Kirby is selling any snake oil..
Cheers
producer
Oct 15, 2013 09:31 PM
san1sjd
Shovelhead
Aug 30, 2012 06:09 AM
gamb
Engine Mechanical Topics
Aug 23, 2009 05:07 PM
producer
24
Apr 3, 2008 12:12 AM
bluezguy
Shovelhead
Jul 27, 2006 12:33 PM
