fuel management needed?
To me, I'd be thinking if I run these pipes/breather without remapping will it hurt the motor? Answer is no, sort of... You'll know the map is off if the motor pings, backfires, or plugs burn white, motor temp goes up, etc. If you have any of these symptoms they will be mild and won't damage the motor as long as you know to back off the throttle, ease on the gas, etc.
But, if you aren't familiar with these symptoms... you could do damage.
As the previous post states HD run very lean to start with and almost all will run better and cooler with remapping. So, you'd never be wrong if you add a PowerCommander or similar device and remap the bike.
What I understand happens, is to maintain 14.6 AFR, which is set at the factory in the ECM, the ECM has about a 1/2 percent range, more or less, to adjust itself.
The engine sees more air flow, in actual fact, and to keep the AFR it is looking for it can adjust some all by itself up to a point. The map cells that are set at 14.6 will adjust and keep 14.6. The problem is the cells that are not set at 14.6. These are open loop and don't change. These are set at a AFR number given it, and the ECM just uses that number to calculate with and the result is what it "thinks" the AFR should be. So these areas can be really lean with a stock program. These areas today are in the low RPM range and real high RPM range, I think above 70 % throddle position, open loop areas. Places that need help already, now really do.
Tuning devices go from there and can change things, especially the areas where things are open loop. But you still have the same O2 sensor. You just work with it, which really works pretty well really. Some tunners do this really well for the whole thing. The 14.6, though left at 14.6 in the program, can be adjusted on another place in the progran, to give actually around 14.2 AFR for closed loop running. And the open loop areas gets new numbers to work with.
Something like that.
If the intake is choked down from stock air cleaner assembly, it really doesn't matter too awful much how free flowing the exhaust is... AC has it choked. Same thing in reverse and one changes the AC.
But............ when one changes BOTH??? All bets are off. Now, your 'air pump' actually pumps more air, and the stock 'tune' still outputs the same fuel as before. MORE air and SAME fuel on an already EPA lean engine means even a LEANER engine.
There is simply a point each of us has to reach to come to the realization that a 'tuner' of some point will simply HAVE to be purchased and utilized.
So... what is YOUR point?
If anybody actually said you were 'dumb' for asking a legitimate question... I would strongly question ANY input from them. ALL of us are dumb from time-to-time, and the ONLY actual dumb question is the one not asked. Do NOT take internet idiots to heart, OK?
Reserch, compare and choose your parts wisely
Check out (dobeckperformance.com) for tuners. Read all the information they have on tuners and how they compare to the others.
There is a lot of misimformation being put out about what you have to do or you will ruin the motor. Will it run better and cooler with fuel management? Yes it will, more after exaust and intake mods. Is it really needed? No. I would do it for the reason that the engine will run cooler and better. Have you ever riden one with mods done without fuel management? I have and I will say other than the engine temp there is very little change.
the ECM thru the O2 sensors, that are used from the factory, can be adjusted about 1/2 of a AFR number.
It can controll between 14.1-15-1. It is set at 14.6 and that is it's midpoint, but this is adjustable in the ECM.
The thing is, if yoy know the AFR at any time in the engine, then you can give those numbers to the ECM with the Tunners.
And to tell you something I have a SERT from Harley I would give away but it is locked to my ECM.
I replaced this with a TTS Mastertuner before the fix came in. Way much better. Lets you find out, using the O2 sensors, what the VE (volumetric efficency) is.
My bike is set where 95% of the time I am in closed loop. But with the TTS I know what the VE is outside closed loop and can give the engine what it needs when it ask for it. And be on the money.
Have been introduced all over again to this TTS becaused I but in a Woods TW400-6 over the Weekend.
