Another Popping Question
Old Aug 19, 2006 | 09:40 PM
bfrmbama's Avatar
bfrmbama
Default Another Popping Question
I have an '03 carbureted Fatboy with 27,000 miles on it. I'm running V & H Bigshot Longs.
Recently, I have been experiencing very noticeble decel popping.
The spark plugs look good.
After searching the forum and reading the other related posts, I am a bit confused as to whether or not I should be overly worried about the popping. Could this just be occurring now because the exhaust has some miles on it?
Old Aug 20, 2006 | 04:19 AM
WoodyHD's Avatar
WoodyHD
Default RE: Another Popping Question
What is the set-up on your bike? Exhaust, intake, etc?
Old Aug 20, 2006 | 10:03 AM
bfrmbama's Avatar
bfrmbama
I have V&H Bigshot Longs with basic Stage I. The engine is stock but I have the high-flow air cleaner and the Keihin Carb has been rejetted.
Old Aug 29, 2006 | 10:21 PM
Road King Ron's Avatar
Road King Ron
Mukuni 42mm Problem solved
Old Aug 30, 2006 | 11:30 AM
rh8234's Avatar
rh8234
If you had no popping after rejetting and installing the pipes and intake and it started popping recently, check for exhaust leaks. If there is a leak where the pipes go into the heads, that can couse popping through exhaust.
Old Aug 30, 2006 | 01:41 PM
Spectrexx's Avatar
Spectrexx
The problem isn't with the type of carb, it's the jetting. No need to buy a new one. First, as was mentioned above, check for exhaust leaks. You have to install them with new gaskets, torque the nuts at the head, THEN attach the pipes to the mounting brackets. If the brackets don't line up, you must shim, bend, or otherwise modify them to align them to the pipes. If you move the pipes around too much, you'll end up with a leak at the head.
Are there baffles in the pipes? If not, then that's part of your problem. Twincams and EVOs DO NOT run well with open pipes. You will lose a LOT of torque and it will be difficult to tune properly.
Next, did you get it dyno-tuned (by an experienced tuner, which usually means NOT at the stealership) after the changes? If not, then get it done and the popping will go away. Incorrect Air Fuel Ratio (AFR) is the cause of most popping problems.
Old Sep 11, 2006 | 10:29 PM
bfrmbama's Avatar
bfrmbama
ORIGINAL: rh8234
This was my problem. The end piece on the pipe (that the flange goes over) broke loose causing an air leak. I had to have the piece welded back on. The guy that did the job said that he sees this problem a lot with Vance & Hines. He said the piece is just spot welded on.
Has anyone else experienced this problem?
Zack DeMott
Carburetor Related
Jun 22, 2018 09:42 PM
busterman2
EVO
Jan 12, 2013 03:07 PM
cbchev68
Sep 12, 2011 06:18 PM
simpkins
May 15, 2008 11:25 PM
green mnm
11
Feb 20, 2008 11:12 PM
