80 ci upper end upgrades
At 60,000 your way past the point of new lifters, so you'll need a set of those.
Valve job, to include mild port mods and valve size increases.
Bob Wood W-6 cam
Wiseco 10.1 cr forged pistons
Dyna Ignition
OE carb, Mikuni 42, or S&S E, all work very well
Cycle Shack, or S/E slip-on mufflers, or most 2/1 headers.
This will go MINIMUM of 80hp and 90 ft/lbs.
If looking for more, them a Wood 8 cam, set at 10.8 cr, with all of the above, and you be witnessing a dyno report that'll show you 92-95 hp, and 92-95 ft/lbs. Folks won't believe that it is an 80"er.
Scott
