problem with 08 street bob need help
Old Jun 17, 2010 | 10:56 PM
gkcarver1's Avatar
gkcarver1
Default problem with 08 street bob need help
have 96ci engine, seII slipons with no baffles, and stage II cone se cone filter, and v&a fuel pak, supposedly tuned to my equipment. sometimes when i go to start it is backfires and makes terrible noises. the majority of the time i can start it as soon as i flip on the run switch and it starts fine, sometimes that doesnt work, when it does it i can open the throttle and wait a few then it will start fine. any suggestions, please help!!!
Old Jun 18, 2010 | 07:25 AM
hogbag07's Avatar
hogbag07
TTS Mastertune, sert, sest will stop your problem with a good tune and a set of baffles.
Old Jun 18, 2010 | 09:52 AM
gkcarver1's Avatar
gkcarver1
thank you, damn it i dont want baffles, but i guess i have to
Old Jun 18, 2010 | 04:31 PM
hogbag07's Avatar
hogbag07
Well you don't need baffles but they will improve the bikes performance and make it run better. I have a TTS mastertune but I'm always modifying my motor and can plug a lap top in and Vtune and be very close to a good tune. PCV and Tmax make auto tuners but the map needs to be close for them to work. The best advice is to do your home work on what tuner suits your engine mods. If you plan on hotting your motor up with a big bore kit cams heads etc you cant beat the TTS, SERT OR SEST.
Old Jun 22, 2010 | 07:21 PM
gkcarver1's Avatar
gkcarver1
the only thing im doing to the motor is what ive already done, se big sucker air cleaner, and seII slip ons. i had the baffles out and it started backfiring. so i bought the v&a fuel pak. tuned that and still same problem, put baffles back in and tuned up the bike, and retuned the fuel pak, problem went away and now it is returning again after one week. should i take it in to harley and get the fuel management re configured?
Silver City Harley
Aug 26, 2020 02:26 PM
Trust
Apr 11, 2017 01:37 PM
drspencer
Apr 15, 2013 06:36 PM
jeeperbrad
70
Jun 29, 2010 02:49 PM
Nickrom32
Nov 16, 2008 09:09 AM
