new member need some help
Old Aug 19, 2010 | 11:57 AM
stubby2121's Avatar
stubby2121
1st Gear
Default new member need some help
I have a brother that needs to rebuild his motor. He has a s&s 88 twin cam and wants to go to a 103. I have done a bunch of research and have found many kits does anyone have any suiggestions as to what is best? we are having a machanic do the rebuild but need to buy the parts
Old Aug 19, 2010 | 12:11 PM
grbrown's Avatar
grbrown
I think you will find the biggest you can easily go to with an 88 is 95ci. To get to a 103 or bigger requires a longer stroke crank which is much more expensive.
Have a search through these threads and you will find a few engine specialists who do this sort of stuff every day. Contact one of them and ask their advice. They can probably supply a kit tailored to your requirements.
There is a thread over in Touring which asks a similar question, which is worth reading. It is worth searching in the main forums as this topic pops up quite often.
Old Aug 19, 2010 | 03:23 PM
prodrag1320's Avatar
prodrag1320
if your going to get stroker f/wheels,ide atleast go 4.5 stroke and go 106" (or bigger)
Old Aug 19, 2010 | 03:33 PM
djl's Avatar
djl
Or, you can case bore for 4.125" cylinder, keep stroke and build a 107". Either way you go, it ain't cheap. True, balance and weld the crank while your at it.
Old Aug 20, 2010 | 05:59 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Or you can go to a 98" without pulling the crank, and see numbers as good.
Our American Iron Magazine build, 98" went 112 ft/lbs 122 hp, sae.
4 3/8" stroke(107") would strike much harder, and make another 10 ft lbs over a broad band. Peak has shown 122/126 sae.
Something to think about...........
Scott
98hotrodfatboy
EVO
20
Jul 27, 2016 05:01 PM
marvo75
Mar 23, 2014 05:31 PM
ChoppedSofttail
Feb 10, 2014 04:01 PM
kkinderen
Jul 1, 2009 02:22 PM
powaypete
May 29, 2009 06:09 AM
