Break In / Problem???
Old Jun 26, 2005 | 01:07 PM
Kess's Avatar
Kess
Default RE: Break In / Problem???
Kess, you don't have to pull the whole cover to adjust the chain. Only the inspection plate which will allow you to adjust the chain.
Thanks Joe - I got it cleared up and obviously you are correct - I also agree that things do seem to feel better over time - I had a bit of some sputtering going on the first 200 and that worked itself out and now after 800 it just seems to be geting better and better - will drop it off for my 1K later today and let you know how I make out when I get it back - The M6 should help things along also -
Heather sorry if I seemed to trying to run over your post - I just wanted to make sure we get what we pay for on the 1K check!
Old Jun 27, 2005 | 03:10 AM
mechanic x's Avatar
mechanic x
6th Gear
check the tension on the primary chain. A loose chain will cause jerking at low speed. Too tight chain will ruin sprockets and will damage bearings.
Elderon 1973
Jul 26, 2019 10:24 AM
AtlantaRider
Dec 24, 2018 12:25 PM
Xguy
Apr 15, 2008 10:33 AM
c5load
Jul 31, 2006 03:23 PM
sporty2005
May 19, 2005 05:11 PM
