Cyl Head Torque
Old Jan 15, 2011 | 12:24 PM
ml crisis's Avatar
ml crisis
Default Cyl Head Torque
Does anyone know a reliable cylinder head torque value number for a stock TC 96 engine?? Can't believe everyone uses this quarter turn process outlined in the manual.. Thanks
Old Jan 15, 2011 | 12:36 PM
wfolarry's Avatar
wfolarry
42 ft/lbs is what Cometic recommends. Done in steps.
Old Jan 15, 2011 | 12:53 PM
djl's Avatar
djl
Use the process in the manual; it works. Why have the manual if you are not going to use it?
Old Jan 15, 2011 | 02:48 PM
tootal's Avatar
tootal
Torque figures are subjective as they get higher. The fit of the nut to stud, the lubricant used and the surface finishes all have an effect on friction. That's why the factory specs say to torque to 16 ft lbs and then go 90 degrees. The threads are all the same so going 90 degrees will give a true distance and pressure on the gasket. If you use the torque numbers, the variables mention before will cause an uneven torque to the gasket. IMO the factory way is the best. Be sure to lubricate the threads and between the head and the washer on the nut. This will make the 16 ft lbs more accurate. Use engine oil since the specs are designed for it.
Old Jan 16, 2011 | 10:50 AM
ml crisis's Avatar
ml crisis
I appreciate your feedback and can't argue with the technical logic, other than it assumes your starting point of 16 ft lbs is equal accross all four. I'd certainly like to believe HD's mfg is good enough that "fit" variances should be very tightly controlled. I guess I have just never seen this before acrross a pretty wide variety of engines, including air cooled aircraft stuff. Again, appreciate the feedback...
Old Jan 16, 2011 | 10:51 AM
ml crisis's Avatar
ml crisis
Thanks
Old Jan 16, 2011 | 02:54 PM
Blk and Chrome's Avatar
Blk and Chrome
I guess you haven't worked on any late model engines as they all are like that now. Yes ALL of them. Get used to it cause it will be on just about everything in the future, lots of torque to yield fasteners. If not done this way you will have a gasket failure for sure.
LeadDoggy
EVO
15
Apr 30, 2019 02:58 PM
priceamp
Ironhead
Aug 12, 2014 10:09 PM
m1crazy
Engine Mechanical Topics
Jan 27, 2013 04:18 PM
ShortFatMexican
Apr 9, 2010 05:07 PM
customsoftail200
Jan 26, 2010 12:59 PM
