Sert thundermax???
Old Feb 23, 2011 | 03:44 PM
RICHIEMACK's Avatar
RICHIEMACK
Default Sert thundermax???
ngine: 95" Screaming Eagle Big Bore Kit w/flat-top pistons, Heads done by Big Boyz Head Porting(cc'd and milled to obtain an 80cc Combustion chamber) Ported With compression releases, 48mm Throttle Body by (HPI), Andrews 37G cams, adjustable push-rods, Bassani 2>1 Exhaust, SERT super tuner, 9.8 to1 compression, 95.08HP/96.06TQ. I feel with this set-up you get great dependability and very impressive performance.
Chassis &misc.
OK GUYS WHAT DO I NEED TO DO TO KEEP IT RUNNING WELL?I WAS THINKING OF A EFI ZIPPERS AUTO THUNDER MAX WHEN I CAN AFFORD IT???WHAT DO I DO BESIDES THE BASIC OIL,IT HAS BEEN DYNOED AND MAPPED AND I DO HAVE THE SERT SUPER TUNER
Old Feb 23, 2011 | 05:49 PM
SURFOR Chop's Avatar
SURFOR Chop
If the SERT has been tuned on a Dyno, you could just let it go as is ....
Very nice build you've got there ... but, a little surprised your numbers didn't top 100/100 with the setup you've described ....
Although I use a Thunder Max with Auto Tune, the benefit is that it doesn't require Dyno tuning once the proper base map has been loaded ... beyond that, it will fine tune itself ....
I guess I am of a mind that 'if it ain't broke, don't fix it' ... and, IMHO that's where you are right about now ....
Up to you though ... the ThunderMax is a great unit ....
Another thing to bear in mind ... since you have a 95" your bike did not come with O2 sensors originally ... I am assuming your Bassani 2 > 1 don't have bungs for the O2 sensors (I suppose they might have and you just plugged them) ... but, if not, you'll have to cut holes in your pipes and weld (or have someone weld) O2 bungs into your pipes ... otherwise the Auto Tune function will not work ....
The AT requires feedback from wide-band O2 sensors (supplied with the unit) ....
The ThunderMax w/ AT is around $800-$900 ... depending on where you get the bungs done, could cost another $40-$60 or so ...
If it were me, I'd drop the incremental funds on something else ... upgrade to floating discs and/or 6-piston calipers ... or upgrade the rear shocks / forks with better springs or cartridge emulators ... etc. ....
R/
'Chop
Last edited by SURFOR Chop; Feb 23, 2011 at 05:55 PM. Reason: add caveat about O2 sensors
Old Feb 23, 2011 | 06:13 PM
RICHIEMACK's Avatar
RICHIEMACK
Thanks chop.good to hear,it has 422 progresive shocks now lowered 2inches front and back im tall and riding 2 up so i might bring it back to stock so i guess for now im good ,
Old Feb 23, 2011 | 06:27 PM
Dalton's Avatar
Dalton
If it has been tuned with the SERT and it is running fine, you will just be wasting dollars to add a T-max unit and will see no gains.
Routine maintenance is all that is needed.
jmg343
Jun 18, 2009 07:52 AM
Lopoetve
Nov 28, 2008 07:16 PM
CCPD
Mar 8, 2008 12:55 AM
pounder35
Mar 7, 2008 10:25 AM
Loch
Aug 11, 2006 01:11 AM
