I expect Harley is working on this.
The thread about Throddle Body size got me thinking again about this subject.
DI is supposed to be a good thing and some Auto's do pretty well with it.
How can we apply DI to what we have?
I expect some on this forum have giving this a though.
My thoughts are:
If the TB is big enough to flow all the necessary air needed, then the question is the fuel delivery.
If we can get all the fuel in during the time the intake valves are open we are doing about as good as we can. With our old time FI.
This means--and this seems to me---the bigger Injectors are the way to go if you have a modified engine.
All in every time. Nothing left to raddle around till next opening.
I figured it up once but the math hurts my head now, the time the intake valve is open, but I thing at 6000RPM comes to 0.0016 of a second max for injector pulse.
May be off a few decimal points.
Anybody thinking about this DI?
Probably be a GM or Borsch thing Harley will use.
You are going down a path that just makes sense. But, I don't think larger injectors are a must to accomplish this. In monitoring pulse width, if it is in the 40% range, enough fuel is bing delivered, at least what is being called for by the ECm is being delivered. In running 4.89 Gm/sec injectors in my 120, they were in the 75% range. Going to 5.3gm/sec, they were in the 40% range.
With direct injection, less fuel will be "hung up" on the manifold walls and in the intact tract, so you actually may be able to go a bit smaller in injector size to get the proper a/f ratio. It depends on how much you want to load the cylinder, and will be very dependent on cam timing and exhaust.
This hurts my head too...too much math and theory!
with DI you can run higher compression, more camshaft without fear. It is the wave of the future. Have to run high pressure fuel system to make it happen if I remember right it's like 2000 psi they run off an engine driven high pressure pump. They can run clean with high HP output. The car makers are making some big HP figures with it now and so far pretty trouble free.
They've been running it in the 2-stroke field on boat motors and sleds for years now. Check it out on Evenrudes and Ski Doo snowmobiles from BRP, very low emissions(even better than 4-pokers in comparasion) and keeping it lightweight and with high horsepower. Been very interesting.
It's time.
Yes, higher pressure in the norm for GDI.
While Delphi makes injectors for GDI systems that operate in the 200+ bar range, one of the leaders in GDI and engine management systems is Bosch.
For EFI Harley's, MM for the years 1995 to 2001, Delphi 2001 to present.
Bosch engine management for Harley's with GDI to debut soon??
