Compression
Old Jul 15, 2011 | 06:58 PM
pjpockets's Avatar
pjpockets
Default Compression
I just had a compression check done on my 2010 Dyna SG. Leak down was 1% on both cylinders, the front was 200# and the rear was 190# Is this telling me something is going wrong but has not gotten there yet? Harley says it is in normal range, but I get the feeling if I had to pedal the thing they would say its normal. Please tell me what you guys think. Mike.
Old Jul 16, 2011 | 06:51 AM
grbrown's Avatar
grbrown
Sounds like "it is in normal range" to me!
Old Jul 16, 2011 | 09:21 AM
djl's Avatar
djl
1% leakdown is well within range, 5% to 10% is great. I wouldn't like the fact that there is 10# difference from one cylinder to another as they should be identical. However, manufacturuing tolerance differnces, like head chamber volume could cause that and it is within acceptable range of 10% variance between cylinders. Top end is in excellent condition.
Old Jul 16, 2011 | 08:21 PM
pjpockets's Avatar
pjpockets
I did not like the 10# difference either, and that is why I asked. Being a 2010, and having misting funeled back into the air intake, there is some carbon build up on the pistons. I suppose some sea-foam, and a hard run with another check is in order. Thanks for writting back. Mike.
Old Jul 16, 2011 | 08:33 PM
BLKBAGGER's Avatar
BLKBAGGER
Thats 5% and would be considered normal.
Old Jul 16, 2011 | 08:35 PM
Blk and Chrome's Avatar
Blk and Chrome
Sounds normal to me. The 10 lb split between the ft and rear I'd rerun them to see if they come up the same. Are you looking for a problem or just checking it out
Old Jul 16, 2011 | 10:16 PM
FXSTaCy's Avatar
FXSTaCy
5% on a production built motor seems pretty good. Lots of variables to consider, the slightest difference can change the numbers a bit. The fuel in the intake and carbon on valves could either be timing is slightly off or a your bit rich. Maybe a tune?
Old Jul 17, 2011 | 01:13 AM
pjpockets's Avatar
pjpockets
I was looking for any reason other then misting or blow by that would cause oil consumption. I use about a ounce and a half every 100 miles. Not huge but not right either. I suppose its being sucked in through the vent tubes. with about 6500 miles on the bike it was perplexing. When I romp on it a little, I use oil faster. The same story as all the others with the same issue. Thanks again guys! Mike.
Old Jul 17, 2011 | 01:56 AM
FXSTaCy's Avatar
FXSTaCy
Oil consumption, not good. 6500 is definitely broke in. I now know why you done leak down and compression. Would have to be rings, valve seals, or possibly crankcase ventilation. Your tests kinda rule out rings. JMO though as my knowledge is more in Hi-Po V8's.
Old Jul 17, 2011 | 10:43 AM
pjpockets's Avatar
pjpockets
It all seems to point to the air intake. Looking for another solution in oil product, or air filter backer plate. No one seems to have a fits all fix for this problem. Maybe I will just ride it till I die of old age, or they stop making sea-foam. Be well all!!!!!!.
Political statement removed by moderator
