sumping
Old Jun 2, 2012 | 07:50 PM
RHillbilly's Avatar
RHillbilly
Default sumping
Pulled crankcase plug got 7 oz with engine hot,bike runs good seems to run a little hot.it has 107 kit maybe why it seems to run hot
Old Jun 3, 2012 | 12:48 AM
jcb1975@yahoo.com's Avatar
jcb1975@yahoo.com
You might want to look into this a bit more, but from what I understand, you do not want to remove that "plug" from the engine case. It is not meant to be a drain plug. It is a locator hole used when machining the cases. That is my understanding, and I have been wrong before.
Old Jun 3, 2012 | 08:05 AM
RHillbilly's Avatar
RHillbilly
Already removed it and put it back no problem bike just seems to run a little hot may look into oil cooler
Old Jun 3, 2012 | 10:27 AM
djl's Avatar
djl
How hot is hot?
The crank case drain plug can be removed without issues if done carefully. Checking for sumping should be done right after a ride while the cases are still hot. The problem usually occurs when tightening; it is a tapered pipe plug and can crack the case if over tightened. Once removed, a little anti sieze will make subsequent removals much easier.
7oz is a little more than I like to see come out of a crankcase; 4-6 is more like it but not enough to indicated sumping. But if the plug is not removed right after a ride and the bike is a softail, oil can drain from the oil tank into the crankcase.
Old Jun 3, 2012 | 11:23 AM
RHillbilly's Avatar
RHillbilly
I checked it right after ride let it drain until it quit dripping got 7 oz my oil level never changes dont know how hot its running head temp gauge stays almost pegged when it i80 deg out no power loss may just need oil cooler with the 107 kit
Old Jun 3, 2012 | 12:21 PM
remmag's Avatar
remmag
would you guys please explain whet sumping is
thanks
Old Jun 3, 2012 | 05:05 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Sean,
Sumping occurs usually when the blind oil pump O ring, has been torn, misaligned, or otherwise installed incorrectly.
When this happens, the crankcase is overfilled with oil, from not being scavanged back to the oil tank, and the crank-postion sensor machined flywheel half(left side),slapping all that oil, does not allow the engine to spool off without a struggle.
Horsepower will nose dive by 25-30 hp loss.
That is usually 16 oz, or more, that'll create that, but once you crest 8 oz, signs of this start to creep in.
Scott
Old Jun 3, 2012 | 05:19 PM
remmag's Avatar
remmag
thanks scott
RadarRider
Jan 12, 2014 08:46 PM
rattlebones
Feb 23, 2010 03:41 PM
CrackOfDawn
Dec 25, 2009 07:33 PM
HDSAE60
Oil Archive (no new posts)
Aug 12, 2009 08:58 PM
cutacroshorty
Jun 25, 2006 01:49 AM
