Pipe slipping off?
Old Aug 21, 2012 | 03:33 PM
fRESH88's Avatar
fRESH88
Default Pipe slipping off?
Need help securing my pipe! My exhaust pipe keeps slipping off the u-pipe. I have it as tight as I can go (spacing issues dont allow me to get in there any further then I can). Any suggestions to help with this issue?? It rattles the hell out of my bike. Thanks in advance!
Old Aug 21, 2012 | 03:35 PM
Esuomm1's Avatar
Esuomm1
What about drilling a screw, something stainless with a pilot hole first or a self tapping one between the pipe and slip on?
Old Aug 22, 2012 | 10:46 AM
seehogs's Avatar
seehogs
I have had luck with using a new clamp or
cutting 2 more slots 90 degrees from the
originals.
This (cutting slots) cured the loose mufflers
problem on my Roadglide
Old Aug 22, 2012 | 01:02 PM
nevil's Avatar
nevil
I've found that if I use the clamps too many times they won't get tight on the pipe even if it's torqued to spec. It can also leak. The surefire way is a rivet or screw.
Old Aug 22, 2012 | 01:58 PM
northeastconfederate's Avatar
Those band clamps HD uses to secure the mufflers to the head pipes are single-use clamps. They stretch when torqued (by design). New clamps should help, and I've used the extra slots also, with good results. In a pinch, I once cut the worm screw housing off a hose clamp & used that for a shim under the band clamp. this let the stretched clamp grip tight & kept the muffler from sliding off.
Djcamis
2014-2024 Touring Models
Dec 25, 2015 02:28 PM
robert v
Dec 9, 2013 07:28 AM
mmesa005
Oct 31, 2012 11:24 PM
bob2002
Apr 8, 2008 08:50 PM
ZJAvy
Jan 19, 2007 10:04 PM
