I don't know why you have to disassemble the bike to get at the ECM. If you ever disconnected the ECM without removing the ECM fuse that could cause a problem.
You just might want to make sure that you have the latest firmware and software and try loading the map again.
Today I installed the module. Download a map, made reading sessions. DRIVE 2 * 25 miles and recorded autotuner. So far so good, but only error P1060 is not a problem. Tomorrow I'll have to go and see whether the check enGheni.
I do not know, but I found the leak from the front collector nut is unscrewed. maybe it was the cause of the wrong fuel mixture. we'll see!
