Yep sure did and did the same process on rg.org. It took just fine on that site. I just cannot figure this one out. 3% smarter is all you need to be to conquer the problem, but today I must be falling short a bit. Bryan
I think, just because you load a pic, it does not get used. there is a box or something you can check that will pull tags like [sigpic][\sigpic] to let you put the pic whereever you want in the sig.. without this, it won't show.. even if you have loaded it in.
yes i think your right,,,,took me a few tries to get it.
