Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Forward controls kit brake rod too long
Old Aug 5, 2024 | 01:18 AM
8ate3's Avatar
8ate3
6th Gear
Default Forward controls kit brake rod too long
Hello, I have a 2013 Sportster Iron 883 and I got the Extended Forward Controls Kit from Drag Specialties.The brake rod is too long. It will either go into the brake pedal or the brake cylinder but not both. Way too long. The part # on the box matches the item so I'm pretty sure I got the right part. Install attempt was done late on Sunday so support was limited.
I'm pretty sure I've used the correct support bracket because everything else lines up fine but I still tested the other one and I'm pretty sure I wouldn't have gotten anything else to bolt in. I'm wondering if anyone has experienced anything similar to this and how they fixed it? Or if anyone has any ideas?
Part #16 on the diagram on the right.
Also, please let me know if there is a more appropriate help section to post this in.
Thanks.
Old Aug 5, 2024 | 08:50 AM
davekp's Avatar
davekp
The instructions say the kit is for a '04 to '09 XL. You got the wrong kit.
Old Aug 5, 2024 | 10:15 AM
8ate3's Avatar
8ate3
6th Gear
Before I started the install I called them and mentioned this and they told me that it's correct. The product name and description says for through year 2013 which is why I bought it. Revzilla confirmed this with Drag Specialties.
Old Aug 5, 2024 | 02:57 PM
davekp's Avatar
davekp
If it doesn't fit, it's the wrong part.
Old Aug 5, 2024 | 07:40 PM
Harley_ish's Avatar
Harley_ish
"Proof is in the Pudding"
Old Aug 5, 2024 | 08:30 PM
Max Headflow's Avatar
Max Headflow
If it doesn't fit it's called "aftermarket".
Old Aug 14, 2024 | 01:51 AM
8ate3's Avatar
8ate3
6th Gear
I watched a YouTube video and realized I had mounted the foot peg support brackets on the wrong sides. The instructions were literally wrong... lol.
After switching the support brackets, everything lined up perfectly! Good thing I hadn't Loctite'd them yet
dirtdobber
Oct 10, 2019 06:36 AM
thoner7
Jun 21, 2016 04:34 PM
usaf_branham
Jul 27, 2014 10:50 PM
lunloon
Nov 17, 2009 10:20 PM
nkauf21
Jan 7, 2008 12:33 AM
